Wiper sweep angle
Can anyone tell me the sweep angle for a 1971 +2S 130
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
My 1970 Plus 2S is fitted with a 130 deg. sweep. It's not the original motor but this range seems just right.
The Lucas wiper motor had a range of gears ranging from 95 to 130 degs. in 5 deg steps.
- Attachments
Windscreen Wiper system.doc
- (74 KiB) Downloaded 48 times
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Thanks for that info, I have trouble getting the balance between the drivers side and the park side. I now need check the motor fitted.
Cheers John
Cheers John
+2s130 1971
+2s130 1971
mmm. I do not think the motor was the only factor in sweep angle. I think the wheel boxes played a bigger part. Look at some of the other Britsh cars of the era - Cambridge and the like, where one wiper sweep was greater than its mate.
As it happens, one of my jobs is to replace my wheel boxes and rack. I will maye pull them out. Remembering my Mini days, I think the sweep is stamped on them.
Give me a day or two...
(reading Foxie's addition, I remember now - peg in the motor wheel determines the rack travel and the number of teeth on the wheel box dictates the final sweep.. as I say, give me a day or two.)
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
Yep, distance of peg from the center sets the sweep.
The number of degrees is usually on the cog, although some cheap replacements do not have it.
CBS car builder solutions sell most of the sweep cog options.
There are some frightful complete assemblies available, beware of cheap Chinese ones.
- Bitsilly
Just re-read your post.
What do you mean you can’t get the balance right?
If one is sweeping differently, just pull it off the spindle to move the relative sweep.
Also, it handy to have a water spray handy because if the glass is dry and the motor tired they will perform considerably differently than in the rain.
Apologies if I am teaching my gran to suck eggs.
- Bitsilly
Bitsilly
The point is if I adjust it to clear the drivers view then whet parked it obstruct the passengers view. Its the spread of the drivers blade, start to return point.
+2s130 1971
+2s130 1971
As Bitsilly said " Yep, distance of peg from the center sets the sweep.
The number of degrees is usually on the cog, although some cheap replacements do not have it. "
You need a wider sweep and re-position the blade(s).
Wiper wheelbox gear size also come into play, some clever people use different size wheels RH & LH in some setups.
Just for fun.
Just for fun.
- Craven
Craven wrote:Wiper wheelbox gear size also come into play, some clever people use different size wheels RH & LH in some setups.
Just for fun.
I've tried a variety of motor wheels, RH and LH park, and different length wipers, but that's a new one on me !
Where are these available from ?
If irregular sweep is something you are interested in then you will need to do an internet search, I don’t recall where I read it may be on a forum somewhere, give your mind a work out figure out the effect of wheel boxes with different size wheels.
- Craven
