Volt Meter - No Movement!!
Hi all, wonder if you can help not the most mechanically minded of people…
My volt meter in my Plus 2 seems completely dead - there is no sign of a reading and no movement when the ignition is turned in.
I am assuming that this means that it is something wrong with the meter as opposed to the alternator?
What is the easiest way to check/access this?
TIA
TIA
- Pointshape
Start by finding someone willing to work on the car. They will start by seeing if the meter is getting a feed to read. A bad connection the most likely cause.
We are supposed to be having fun, are we not?
- USA64
You need to figure out the right wiring diagram for the car and track down the feed for it.
I had this on my car, s130 with in dash fuses, I'd blown the far right fuse that feeds the gauge, reverse lights and brake lights.
- mbell
