Interesting tattoo on the bonnet skin
As I was sanding the bonnet of my Plus 2 a couple of hours ago, I discovered a puzzling tattoo embedded in the bonnet skin. See attachment below.
Has anyone discovered the same kind of marking? Is this usual?
I made already some progress elsewhere ( surroundings of the bonnet, front wings) but no other marking so far
cheer
François
cheer
François
Fran?ois
Lotus Elan Plus 2 130S Big Valves
LotusEngineeringBuff - Second Gear
M20 was the Lotus development number for the +2, when it was being designed and tooled up.
Perhaps the 1 1/2 refers to a lay-up of fiberglass for the bonnet, obviously the word at the bottom of your tattoo.
Depending on the age and Unit No of your car, the bonnet could be original to it. Or it could be a pre-production bonnet that later found its way onto your car whilst it was being built.
I am aware of two prototype M20 cars, one of which was the Metier, as well as one pre-production car, white and registered KPW 176D.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
The 2nd possibility is more likely. My car being a late Plus 2 130S from 73 06
The full number is 7306 1457L
Thank you for the info
Fran?ois
snowyelan wrote:Bonnet being plural ....
Really? Not in my French or English dictionaries.
Meg
snowyelan wrote: Can you tell if it is embedded below the gelcoat or is it marker that has stained the gelcoat?
At the risk of pointing out the obvious, unless the original writer could write in ‘mirror writing’ it must have been written on top of the gel coat, after the panel was released from the mold.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
I was asking because it crossed my mind that the batch of bonnets (being plural) were made too weak and the note was for an additional F/G reinforcement layer, with 1 1/2 being the extra weight. Thinking about it more I suppose that the reinforcement layer would have been simpler to add on the inside, so the text wouldn't have been under an added layer.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
Andy8421 wrote:snowyelan wrote: Can you tell if it is embedded below the gelcoat or is it marker that has stained the gelcoat?
Well, as far as I can tell, the writing is under the gelcoat. It must have been written in mirror by a smart fellow
Fran?ois
I have even more "secret codes" on the body. If I look more carefully I will probably discover a secret map indicating a burried treasure
Fran?ois
Users browsing this forum: Alastair.hazell and 7 guests
