Lotus Elan
Plus 2 rear ride height / springs - again!
PostPost by: KevinM » Tue May 02, 2023 9:09 am
Hi everyone,
The rear ride height on my plus 2 seems too high (it has Spyder rear springs - non adjustable) and I'm convinced the angle that the rear drive shafts sit at is a large factor in the early demise of my donuts.
Has anyone got recommendations for a set of springs that give a decent ride height / drive shaft angle?
Kevin
1972 Elan Plus 2 130S
KevinM
First Gear
First Gear
PostPost by: berni29 » Tue May 02, 2023 8:11 pm
Are these the smaller Spyder 2 1/4" (I think it is) that you are talking about?
All the best
Berni
berni29
PostPost by: h20hamelan » Tue May 02, 2023 8:51 pm
I believe 12” is the lower accepted. And 14” is the taller. Might be 12.7 and 14.3 ?
https://www.google.com/search?q=lotusel ... s-wiz-serp
https://www.tonythompsonracing.co.uk/pa ... orms-pair/
Love your Mother
Earth
Location: RACECAR spelled backward, is——RACECAR! The Faster You Drive...The Slower You Age
PostPost by: mbell » Tue May 02, 2023 9:59 pm
What is the ride height to top of wheel arches? from memory its normal for them to be 25-26" at rear and look high, then the front 1/2/" to inch lower.
PostPost by: h20hamelan » Tue May 02, 2023 10:14 pm
And is that loaded with 500lbs + driver or so?
Does one measure from centre of wheel/hub to wheel arch?
Love your Mother
Earth
PostPost by: KevinM » Wed May 03, 2023 7:53 am
berni29 wrote:Hi
All the best
Berni
Hi Berni,
No normal sized springs I believe, a direct replacement for the ones they took off when renewing shock absorbers.
Kevin
KevinM
First Gear
First Gear
PostPost by: KevinM » Wed May 03, 2023 7:54 am
mbell wrote:What is the ride height to top of wheel arches? from memory its normal for them to be 25-26" at rear and look high, then the front 1/2/" to inch lower.
I will check and get back to you.
Kevin
KevinM
First Gear
First Gear
PostPost by: KevinM » Wed May 03, 2023 7:55 am
h20hamelan wrote:I believe 12” is the lower accepted. And 14” is the taller. Might be 12.7 and 14.3 ?
Many thanks.
Kevin
KevinM
First Gear
First Gear
