ANYBODY GOT A SECONDHAND COMPLETE STEERING COLUMN?
Hi Everyone & thanks for taking the time to look at my post!
I'm looking for a second hand steering column the whole assembly from steering wheel end to where it joins steering rack etc.
I don't have anything!!!
Any help much appreciated.
Dave.
- DreamBuilderiHope
Oh thank you so much That's a really big help!!!
Dave.
Dave.
- DreamBuilderiHope
There are two distinct versions, the later cars have an integrated ignition switch/steering lock, the early cars don't.
Before installing, I would replace the nylon(?) bushes between the inner and out columns not difficult or expensive and it can make a big difference.
- mikealdren
Thanks for the advice!!
Need to find one!
Need to find one!
- DreamBuilderiHope
How soon do you want the assembly?
I have one, inner and outer column with integrated ign lock, indicator/dip switch, binacle and wheel.
I am in the throes of a lhd conversion with an Escort steering column. Once I know the Ford column will fit, the original will be discarded.
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
If you replace the Bushes there is an improved version much better than original at "Rimmer Bros"
- alan.barker
Hi Jon,
Sorry but I should have said Rimmer offer 2 choices. I suggest the better improved one.
- alan.barker
The original Nylastic bushes have a split nylon insert bearing surface, modern replacements are moulded in one piece and are longer so provide better support for the inner column.
S4 DHC
S4 DHC
- oldelanman
How do you remove the older bushes and put in the new ones?
Dave.
Dave.
- DreamBuilderiHope
Is the inner upper Column easy to remove to replace it with a new one?
Any help much appreciated,
Dave
Dave
- DreamBuilderiHope
DreamBuilderiHope wrote:How do you remove the older bushes and put in the new ones?
Dave.
Hi Dave,
This thread details methods of bush replacement. viewtopic.php?f=42&t=49211&p=357076&hilit=+column#p357076
In it I have explained my method, using a threaded bar to pull the bushes in. The standard method is to knock them in using a hammer and some form of drift. Use whichever way works for you,
As you're new here can I also suggest that you make use of the "bookmark topic" function that is at the bottom of each page. I have found it to be really helpful to save various topics for future access when it came to doing various tasks. You can then find them under "manage bookmarks" within your "forum profile". Apologies if you've already worked this out for yourself.
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
Users browsing this forum: pdenton26 and 18 guests
