Electronic ignition Lucas AB13, need wire diagram
A year or 2 ago I bought an Elan +2 JPS 130/5 - 1974 in pieces and slowly but surely rebuilding it.
In the one of the boxes I found a Lucas AB13, but the distributor is missing.
I have found a replacement distributor but I am missing the wire diagram to make sure that I connect it the right way.
The connector on the AB13 has 6 wires, 2 black, white, white-black, red and green
The connector that was attached to the car had the white wire connected to the +12V, one of the black wires was connected to the negative.
A separate connector (I suspect going to the distributor) has a black, red and green wire, black being presumably the negative.
Could somebody help me with this, looking forward to your reply.
Kind regards Toon
Kind regards Toon
Toon vd Wiel
1970 Elan S4 SE
1974 Elan +2S 130/5
1970 Elan S4 SE
1974 Elan +2S 130/5
DutchTony - First Gear
Google is your friend - http://www.the-daily-rust.com/kontakt/installationinstructionsmontageanleitungen/classicmini/index.php
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Users browsing this forum: Elan45 and 13 guests
