Fitting bumpers
Last time I simply bolted them on and used a rubber penny washer between the bumper and the body and a stainless penny washer on the back side
But SJ Sportscars show a thick rubber buffer for bumper mounting - is this necessary and where does it go?
Any other tips - was thinking of put a self adhesive foam strip between the bumper and body just to isolate it.
- jono
Hello jono, just refitted the front bumper on my +2 and put the rubber back from whence it came from.it sits sandwiched between the body and the underneath of the bumper so there is a gap all around.I used stainless penny washers under the nut to spread the load.The rubbers I removed we’re still good after 50 years not sure foam will stay the course.
72 Elan +2S 130/5
Put in the garage after a mot pass in 2012,trying to make it back out.(Almost there)
- Steve Brooks
hi Jono,
could you tell us the part number of the rubber buffer please. I don't suppose you've mistaken them for the rubber buffer for Headlamp Stops or For the rear of the Boot Lid.
- alan.barker
Hi Alan,
Its A050B1940Z, definately a rubber 'block' to isolate the bumper from the body. I have some thick rubber sheet and can make some myself
- jono
Steve Brooks wrote:Hello jono, just refitted the front bumper on my +2 and put the rubber back from whence it came from.it sits sandwiched between the body and the underneath of the bumper so there is a gap all around.I used stainless penny washers under the nut to spread the load.The rubbers I removed we’re still good after 50 years not sure foam will stay the course.
Thanks Steve, good to know - I never even knew these existed!
- jono
Hi Jono,
Just fit rubber washers. I've used rubber Tap Washers and just made the hole a bit bigger in the past. You need to put sealant around to number plate lights wires to stop flooding in the Boot.
- alan.barker
Tap washers - great suggestion, cheap as chips from Wilkos!
Last time a put a foam strip around the indent in the body below the numberplate lamps to seal it from ingress
- jono
