Metallifacture jack
Can someone provide the measurements for the lifting end of a Metallifacture jack?
- pudge2260
Please advise which type of Elan this is for.
- Billelan
What lotus Elan..? If it's a Plus 2, I can provide what you need.. pls let us know..Tony
- TonyA
1970 Elan +2, jack end fits up into the sill tube.
- pudge2260
Here are pictures of the jack and ratchet of my 1971 Plus 2 S130
Hope they come thru: I ve never posted photos before.., ! Tony
- TonyA
Here is a side view of the jack from my 1971 plus2 S130 ..Hope it helps.. Tony
- TonyA
Pictures are worth a thousand words, thanks for the pictures and your time.
- pudge2260
As an aside, I have one of these jacks but not the handle. Assuming no damage, is the jack worthwhile enough to seek the handle, or would I be better served with something else, such as a modern lightweight scissor-type with modification to engage the jacking points? Yes, I've seen the thread about how to do that.
1969/70 Elan Plus 2 (not S) 50/2036
The Veg - Coveted Fifth Gear
I tend to look for original parts and accessories when viewing a vehicle. All of that shows well at car shows and meets.
The Metallifacture jack for the Elan +2 is actually hard to find. I ended up with a Metallifacture jack from a Cortina, that is why I was looking for the measurement of the jacking pin.
Correct handles come up quite often on eBay UK.
Have you changed the side sills, if you haven't make sure to do a thorough inspection of all 4 jacking points. Each jack tube is welded in 2 spots. The top weld on mine was good but the bottom was rusted away, so no support.
If you think that you would like to part with the jack, let me know.
- pudge2260
Such handles come in various length but also square hole size, make sure you check some dimensions before embarking on long distance shipping...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
I've recently refurbed a +2 jack , hopefully in the correct colour if there is one ? , are the later ones black ?- seen some red ! are there any rules to follow ?.This came from Mark K in the forest and still had quite a bit of its original battleship grey paint.
This one came with a +2 but is obviously from an elan [ which i don't have] , thought i might as well blast and paint this while i was at it, has a different style of metallifacture frame , over painted in hammerite it still had the grey paint inside.
50/0024
- steveh
The Metallifacture jack , wether with the 'spike' for going into the sill holes as in the Plus2 or the channel type that goes on the baby Elan, both share one disadvantage over their scissor equivalents: they are useless if you have a puncture on a wheel quite close to a kerb ! I know from experience..!
Tony A
Tony A
- TonyA
