Plus 2 restoration
• Page 1 of 3 • 1, 2, 3
I am currently building an Elan Plus 2 fast road "restomod". I say restomod because it will be modified to fast road specs using nearly all Lotus components except for a Spyder chassis. I had originally intended to build a Zetec conversion but that is currently above my skill level. I also don't like their apparent high stance and low ground clearance to the exhaust system. Instead it will be powered by a 1700 cc tall block motor or long stroke 1700 Lotus block. The body I am using has sat out in the weather for about 30 years but has no visible body damage (no bondo) but the surface is worn past the gelcoat in spots. Needless to say I have plenty of work to do but I'm really looking forward to it
. The chassis and drivetrain are mostly complete but they are the easy parts.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Have fun with it, looks like a great project!
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Wot Phil sed! Can't wait to see it come together!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Speaking of brakes, has anyone run a Plus 2 without the servos? Is pedal pressure required excessive? I would like to eliminate the expense and complication if possible.
67 Elan +2
67 Elan +2
- seniorchristo
Looks like a great project. I am just starting to build up my +2 Spyder chassis. Do you have anything to say about brake and fuel line placement and materials?
Many thanks
Berni
Many thanks
Berni
berni29 - Fourth Gear
Berni
My chassis is almost complete except for the brake lines. I am waiting on my decision whether or not to add servos.
I have a kit to make the brake line flairs but I need to research the types of brake lines available before I proceed. I will keep you posted,
67 Elan +2
67 Elan +2
- seniorchristo
I run servo less on my car, have used 5/8" single master and just switched to 0.7" tandem master. Running ebc green stuff pads. I find pedal pressure fine, wouldn't describe it as light but have never found myself thinking they are heavy.
On a rhd removing the servo also simplifies the brake line routing, just straight from the master to the multi way connector on the right chassis rail.
For pipes iif just use cunifer. Original fitment was bubble flares rather than the double flares used in US cars.
- mbell
I ran 0170N for a very short period of time with no servos and a 5/8" bore master cylinder. It was a frightening experience with hopelessly inadequate braking and the sound of fiberglass cracking at the pedal box mounting. I did not use modern brake pads but I doubt they would make up for the nearly 3:1 servo gain.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
That's interesting, the smaller diameter piston should reduce pedal effort as well. I'm building a Zetec car (Sierra brakes) and wasn't intending to use a servo, I'll keep my options open about adding one.
- mikealdren
It's great to see another one of these cars being saved.
I hope it takes you less than the 32 years I took me!
- woodie
I used copper brake pipes and cunifer fuel pipe. Have used both as brake pipes on earlier projects with no problem. Refurbishing the servo is not a great expense with the kit being around £100 and if you can refurb a master cylinder you can refurb the servo. If not fitting a servo Spyder sell a strengthening plate that fits round the pedal box to reinforce the GF.
Elan +2
Elise mk 1
Elise mk 1
- Donels
I deleted the servos and switched to the .7 master as well. Pedal effort is completely reasonable; I can lock wheels if I really want to. Pedal FEEL, on the other hand, is rather lacking but I get used to it really quickly and seat-of-trousers input makes up for it.
2012 BMW R1200GS
2012 BMW R1200GS
Veg
What brake pads do you use? Maybe certain pads make for easier braking.
67 Elan +2
67 Elan +2
- seniorchristo
Aluminum sill members
I had some aluminum structural channel leftover from a work project. Replacement channels seemed heavy and expensive so I decided to try and fabricate my own. They weigh about 14 pounds each including the plates and hardware. It was alot of work
67 Elan +2
67 Elan +2
- seniorchristo
seniorchristo wrote:Veg
It's not the ease, it's the feel. I can stop easily, I just feel the feedback through the seat rather than through the pedal. The pads are whatever were on the car when I bought it and appear to have plenty of life left in them and all calipers have been rebuilt.
2012 BMW R1200GS
2012 BMW R1200GS
