• Page 3 of 4 • 1, 2, 3, 4
I noticed my cam cover has a raised rectangular section on both sides, more pronounced on the left. I thought it was just a mark on the paint where someone had stuck a label but it is cast into the cover. Does this mean the cover is from something else, Cortina/Escort perhaps ?.
20211122_211113 by Robin Derrick, on Flickr
- 111Robin
Another query, the inlet tracts have vacuum takeoffs, I presume this is a modification by a previous owner to enable the carb's to be synchronized by connecting a vacuum gauge to each cylinder ?
20211122_210240 by Robin Derrick, on Flickr
- 111Robin
111Robin wrote:Another query, the inlet tracts have vacuum takeoffs, I presume this is a modification by a previous owner to enable the carb's to be synchronized by connecting a vacuum gauge to each cylinder ?20211122_210240 by Robin Derrick, on Flickr
Those inlets are not standard so you are probably right about a previous owner.
Some Dellorto carbs have vacuum takeoffs, Webers do not. (As far as I know)
111Robin wrote:I noticed my cam cover has a raised rectangular section on both sides, more pronounced on the left. I thought it was just a mark on the paint where someone had stuck a label but it is cast into the cover. Does this mean the cover is from something else, Cortina/Escort perhaps ?.
The cam covers made around 1968 used modified moulds when the Lotus script was moved from the top of each cam to the front. A "shadow" was left from removal of the original Lotus script.
There are some wonderful engine bay photos in this thread. The desire of some owners to return the car to the original condition it left the showroom is understandable but I do wonder if sometimes a lot of important history and 'story' of the car is lost by this. The age of these cars means that a lot of 'upgrades' took place not long after the car was made and so are as contemporary and interesting as the car itself. I would certainly would not respray a scratch in the cill that Ms Peel made with her stiletto boots. Because the third Duke rebuilt the west wing two centuries after the house was built does not make a good argument for complete restoration to an earlier time. Of course all owners can do what they wish with their property but maybe we will end up with many factory fresh cars and few of the cars that record the evolving history of the cars life.
- Washer
Washer
Interesting point, with which I agree. My engine bay, as pictured above (and indeed the whole car) had been subjected only to downgrades (radiator from an unknown source, earlier type cam cover, carbs with missing filters, Jaguar washer bottle etc etc) so I had no qualms about returning to near original.
Ian
Ian
- Lotusian
My engine bay is just a mess, black paint on everything, bodged wiring, bodged brackets, not nice at all, so starting from scratch is the way to go. I have a couple of 50+ year old cars with engine bays still original but looking 50+ years old and I'm keeping them like that, not doing anything cosmetic just making sure everything works. I do prefer patina but hate bodges.
- 111Robin
Rohan-Thanks for the cam cover info. I never noticed the moulding until the black crackle finish started to peel and I removed the rest for the bare aluminum look- makes sense as my car has Oct 68 build date.
Thanks, Mark Whitaker
69 Elan S4 DHC
45/8396
69 Elan S4 DHC
45/8396
- mwhitaker
Making some progress at last. Engine bay rubbed down and old paint removed from block/head, next step is to fill redundant holes and prep' for paint. In the meantime the carburetors have been nicely restored by Paul at Weber Carb Reconditioning Services. Wiring harness from Autosparks will be arriving this week so once everything is painted this will be the next job on the ever growing list.
- 111Robin
Hi, can I just point out that your engine mountings are fitted the wrong way up.
Brian.
- ncm
Thanks, they're only on temporarily, I removed them to jack the engine up to remove the manifold, I'll take note of their orientation after I reinstall the manifold.
- 111Robin
Wow, Yes, if you don't correct that and if the rubber bonding fails the engine will drop out of the car.
Rubber bonding failures are quite likely with modern pathetic rubber, methinks.
billwill wrote:Wow, Yes, if you don't correct that and if the rubber bonding fails the engine will drop out of the car.
As I said the mountings are only installed temporarily, not even tightened, they will be replaced with new ones once I've completed the engine bay.
- 111Robin
Best to put Engine Mounts correct now then no contact with Camcover and Bonnet
The mounts are not the same part n° each side
I would keep the added intake fittings so you can use a "Carb Tune" to balance carbs in 5 minutes. You can fit small Plugs in Holes so they don't show too much.
- alan.barker
