Time for our favourite game… ‘what’s this noise?’
• Page 1 of 3 • 1, 2, 3
Hi all, happy Friday all and hope you have some sun where you are.
Had a cracking drive with my +2 this week but can anyone help with this strange ‘whirring’ sound usually noticeable when I come off the loud pedal.
https://youtube.com/shorts/LgtuPSbC9CM?feature=share
Thanks and have a good weekend all!
Vimal.
Vimal.
- hysteric
It might be the exhaust contacting something on overrun - worth a quick look?
You could also have a look at the diff mountings to check they are tight. Also check anything that might be loose under the car, or anywhere really. After that, if no joy, you have to try and pin-point the noise.....
Dave Chapman.
Dave Chapman.
- david.g.chapman
Can’t comment on a plus 2, but I sometimes have to tighten the dash screws a little on the Sprint
'72 Sprint
'72 Sprint
- richardcox_lotus
Slack timing chain ??
Check it
Check it
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
That’s a gearbox buzz or rattle, to verify remove the gear lever gaiter and any padding and take it out for a run, the noise should become obvious if it is gearbox…
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Hi Vimal
Did you identify your noise
We would like to what it was
+2s130 1971
+2s130 1971
+1 exhaust
While under there check the UJs. I had a failure of these that sounded similar on the overrun.
Cam Chain? Would have gradually crept up on you without you noticing..
Is the noise new & fully formed when it became apparent or has it been gradually getting worse?
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Hysteric,
Take a look at the long post in the Plus 2 forum with the name "Metallic Rattle." Two of us on that post have (and for me still have) the noise you have recorded on overrun. Mine sounds like it comes from the gearbox and, although several knowledgeable mechanics have been inside it, no one is able to eliminate it. I explored other sources of the noise even going to ridiculous lengths including having my drive shaft shortened. Finally, I put some sound proofing material around the shift lever, put the center console over it and have learned to live with it.
I hope that someday someone has the answer to this annoying noise. I've given up trying to find it..
Lee
Lee
Jackson, CA
- Harvey
Hi Lee,
I just read through your 2019 saga of the Metallic rattle... top marks to you for perseverance and leaving no stone unturned!
I guess the only thing left would be to rebuild the box from scratch?
regards
Iain
regards
Iain
72 Sprint - 0363E
74 S130/5 - 1931L
74 S130/5 - 1931L
- sprintsoft
Harvey wrote:Hysteric,
Lee
Hi Lee, that is a truly epic battle you've had and hats off to your determination! thanks very much for the pointer.
With regards my car, I've taken it out on 1 hour journeys again and it hasn't presented again. Perhaps very very slightly but not anything like it was when I first heard it.
Do Elan's self fix?
I think I will still have a nosey under the car for anything loose.
- hysteric
Users browsing this forum: Andrew G, smiths everest and 21 guests
