Front suspension : the new bushes started to slide
hello,
I just rebuilt the front suspension of my 1970 Elan + 2S with new Spax adjustable shock absorbers, new bushes, new top ball joint, etc.
But have a problem with the Wishbone Bushes : after less than 10 miles of driving the bushes started to slide from their housing - see photos attached.
what can be the origin of the problem and did we miss something during their assembly?
Many thanks for your help
Best regards
Greg
Best regards
Greg
GregSCF - New-tral
I haven't checked but I would think that the washers outer diameter needs to be bigger than that of the outer of the bushes to stop the arm from sliding off, as the nut will pass right through the 'hole' that the bush fits in.
What did you do with the washers when you dismantled it?
Greg, get used to using the search capability on this site, lots of good info...
As you can see in this example you can do very specific searches & usually end up with good results...
p.s. Your washers are 1/2" ID & large OD!
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
thank you very much for the info,
surprisingly, there was no washer in place before.
but maybe the wishbones were stretched when we removed the old bushes? and are now too loose to keep the new bushes in place?
billwill wrote: What did you do with the washers when you dismantled it?
GregSCF - New-tral
Maybe you could use Loctite on outer Dia of bush to stop moving in Wishbone.
- alan.barker
Definitely need the large washers, but that would only limit this to contact with washers, did you press bushes with no lubricant as they are an inference fit. I've never had them move and have not resorted to using locktite etc.
Alternatively have you spaced the outer ends of the wishbones of fitted incorrect width top ball joints?
Vaughan
Vaughan
- vstibbard
have you put the Wishbones the wrong way round That's to say back one to front and front one to back
- alan.barker
alan.barker wrote:have you put the Wishbones the wrong way round That's to say back one to front and front one to back
There's no difference front to rear ... or side to side.
S4 DHC
S4 DHC
- oldelanman
oldelanman wrote:alan.barker wrote:have you put the Wishbones the wrong way round That's to say back one to front and front one to back
OK. What do you suggest the problem is then
- alan.barker
Just check that when the wishbones are back on, with the washers in place , that the gap they leave at their outboard side is the same as the width of the ball joint........sounds obvious I know.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
