5 speed angle drive
Gents,
the speedo in my S3 with a 130/5 5 speed went dead. I suspect the angle drive has packed up, but I can‘t find any detailed information on the drive in the +2 workshop manuals. Isn‘t there any info on the angle drive in the manuals? Further more, can you guys help me out with information on the angle drive. On my Volvo 1800 S, the angle drive is connected to the gearbox speedo drive via a short section of speedo cable. Is this also the case with the Lotus gearbox (I don‘t remember the time when I assembled it.
Thank you!
Philipp
Thank you!
Philipp
- phil1800
The angle drive is connected directly to the gearbox, rear and right of the gearstick. Access is likely tricky with gearbox in situate, likely need to remove engine/gearbox to get good access.
- mbell
gjz30075 wrote:I was able to access the speedometer angle drive by removing the gearbox mount and allowing it
to drop. Still difficult but easier than an engine and gearbox removal.
on a 2 seater ? quite interesting then, if you confirm I'll have to give it a try...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
gjz30075 wrote:I have small hands and also used used long channel locks. Not easy.
would you post a photo of these long channel locks when you get a chance ?
I've been postponing fiddle with the speedo cable for years now awaiting for an engine pull out which has not been justified yet, so make do with an anachronic gps speedo in the meantime.
S4SE 36/8198
