Elan +2S130/5 complete restoration
Hello dear friends,
i'm proceeding my "introduce yourself" post with this one as my restoration project could interest some of you.
Here are some photos :
We got just one live, carpe diem !
- olivebdr
Engine stripped out in workshop :
- olivebdr
When i came back from previous owner, the engine over heated on the motorway. It was due to a radiator leak.
The 4th cylinder was damaged. During inspection, it appears that valves, crankshaft and pistons were realy tired and needed to be restored...
- olivebdr
That should keep you busy for a while!
Good Luck. This is the place for advice.
- vincereynard
Thanks Vince,
I?m actally working on front suspension. And i m ? little bit confused with the trunion.
I previously dismantled everything, cleaned up, and traeated with anti rust and paint.
I began to re assemble the front suspension and nothing precise to be found on workshop manual about these trunion except the use of Ep90. At the end, i have no idea how much i have to unscrew the trunion before assembling it... 1? 2? Complete rotation ?
- olivebdr
Welcome to the site. You'll find a 50:50 split between using grease and oil in the trunnions - I sit on the fence with oil in one and grease in the other!
But to more serious matters. Make sure you have the trunnions the right way round, as one is left hand thread on the trunnion and vica versa for the other. I can't remember which side goes on which, but someone here will!
Then screw the trunnion all the way into the upright until it bottoms out, then unscrew it just enough to give the 30-40 ish degrees of movement each 'way' from the 'rest' position to allow for the steering movement. You want the minimum amount of unscrewing so you keep the maximum bearing surface from screw thread in the upright.
HTHs Matt
HTHs Matt
Visit me on matthewvale.com
Matt Elan - Fourth Gear
I believe it's the same as the wheel hubs , right hand threads on the right hand side , left hand threads on the left side.
Thanks for your advices,
I did just one rotation from the Max screwing position. And fortunately there is a L on one trunion witch i believe is for left side
But i will check left thread into left...
I will post photos shortly
- olivebdr
that was a loooong week end... i did not finished everything i would but here it is.
- olivebdr
Rear side is a huge job. I spent the afternoon to understand the right way...
- olivebdr
