Ambient temperature probe location
Welcome. It is fasten in the front of the nose somewhere near the air box I think. The tube runs down the ledge of the fibre glass body that just above the chassis and under the carbs. I think it is fastened with screw on black plastic wire fasteners on my car.
- mbell
Mine came out through a hole big enough for the bulb to fit through and then with a rubber grommet to seal it on its own below the LH bonnet lock and followed the wiring loom down to the nose along the LH side. You can see it in the bottom RH corner of the attached photo
My bulb was just behind the lower lip of the grille opening in the center. The bourdon tube was routed out the right side of the fire wall, even though the gauge is on the left side of the dash. Currently what remains of the bourdon tube is currently coiled up under the dash awaiting a proper repair.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
My '70 +2 (Fed) has the same hole location and routing shown in Rohan's photo, seemingly original. The bulb was located in the nose, but simply clamped to the lower fiberglass behind the grill. I don't know if that location was original or not.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Mine comes out of the same hole as the speedo cable, just below the offside bonnet catch then runs down to the body ledge on the inner wing under the carbs, passes under the radiator side bracket into the nose and is then cable tied to the air filter trunking until it gets to the bracket on the filter case as Rohan has described.
Robbie
Robbie
Hi Roy here is a pic of the outside air temp probe this is the correct position as this car was sold by me when I was a dealer back in the day and is unmolested the clip is none original but fixed in the original position Kind regards David
- DavidLB
DavidLB wrote:Hi Roy here is a pic of the outside air temp probe this is the correct position as this car was sold by me when I was a dealer back in the day and is unmolested the clip is none original but fixed in the original position Kind regards David
HI David
I am sure it was original at some time on some cars
So what model and what year ???? Lotus are notorious for un-documented changes, so more details are really needed. This site does a great job of teasing out all those variations where possible
