Lotus Elan +2s 130/5 restoration
Hi Guys,
Here is some pictures of my Elan +2 when I purchased it some years ago. At the beginning of 2017 we started to dismatle the car for the complete restoration. I will show you pictures about the work done until today (now we are working on the body).
Thank you
Edo
Thank you
Edo
https://it-it.facebook.com/lotuseuropat ... onproject/
Lotus Elan+2 1973
Lotus Europa TC 1971
Lotus Elan s2 1964
Lotus Elise s1 1997
Lotus Esprit s1 1976
Lotus Europa s1 1967
Lotus Elan+2 1973
Lotus Elan s2 1964
Lotus Elise s1 1997
- Edo91
512BB wrote:Why did the car need complete restoration Edo, it looks in great condition and original?
Leslie
Hi Leslie,
The car from the pictures seems good, but it needs a new paint, engine rebuilt because there wasn't compression and when we removed body from the chassis, found some stress cracks in the front of the chassis.
In the follow pictures, you can see the rolling chassis and chassis after welding(ready to be painted)
Edo
Lotus Elan+2 1973
Lotus Elan s2 1964
Lotus Elise s1 1997
Lotus Elan+2 1973
Lotus Elan s2 1964
Lotus Elise s1 1997
- Edo91
Out of interest how did you connect the hoist to the body when lifting it?
Looks like chain down into engine bay area but I'd expect that not to be very balanced.
- mbell
mbell wrote:Out of interest how did you connect the hoist to the body when lifting it?
We made a home made and not so safety structure like this in the pictures
Lotus Elan+2 1973
Lotus Elan s2 1964
Lotus Elise s1 1997
Lotus Elan+2 1973
Lotus Elan s2 1964
Lotus Elise s1 1997
- Edo91
Thanks Edo91. I've been thinking about doing a similair thing if I ever get around to doing the chassis swap on my car, plan to use the jack points in the sill members as primarily pickup points.
- mbell
I've posted this pic of my body lift before, but maybe you haven't seen it. I welded up two triangular side frames from 1" box section, which hook into the jacking points, and join them with a 2" box section across the top.
You will notice two concrete blocks on the bonnet. The centre of gravity of the +2 bodyshell is closer to the rear door edge, and not midway between the jacking points, as I discovered.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Thanks. I can't weld but expect to make a similar frame by other methods. Need to do some testing to see if the angles/clearance will work using a engine hoist.
- mbell
