Reproductions of Plus 2 ID plates . . . ?
PostPost by: Sea Ranch » Fri Apr 07, 2017 5:01 am
Greetings,
Had always thought I would commission some repro plates for my car: engine bay id plate and vehicle emission control info plate and the "manufactured by Lotus . . . " plate on the driver's door jam.
Just wondering if anyone else has had these done, or knows of their availability somewhere, or of a company which does a good job of these? I guess a limited run of them could be done, too, if there were need/interest.
Below are the specific plates I'm looking for:
img_0033.jpg and
img_0035.jpg and
img_0026.jpg and
Randy
Sea Ranch
PostPost by: frogeyesimon » Fri Apr 07, 2017 7:37 am
SJ Sports Cars sell the under-bonnet plate (your second picture). Not sure about the others
1968 +2S 130 50/1189
1959 Frogeye Sprite
frogeyesimon
PostPost by: pharriso » Fri Apr 07, 2017 10:46 am
I've seen the emission (first) plate for '72 & '73 cars as well... let me try & remember where! :roll:
Update: RDent has 1972 plates for $24
Never seen the last plate available anywhere....
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Sea Ranch » Fri Apr 07, 2017 2:27 pm
Thank you, Simon and Phil! Excellent! The chassis id plate is perfect for me; the emissions one not quite. But at least I could contact Ray to see who makes them and then develop some artwork to send them.
Thanks again,
Randy
Sea Ranch
PostPost by: Jason1 » Fri Apr 07, 2017 6:30 pm
Jason1
PostPost by: Sea Ranch » Sat Apr 08, 2017 5:14 am
Interesting; thanks, Jason.
The seller in your ebay link is John Viner of vin-plate.co.uk. Have had one correspondence with him. The plate he is offering in that ebay auction is plate number 4-682003 (top right corner) and is very similar to mine but not quite the same.
The plate SJ Sportscars is offering (under Elan Plus 2, Chassis, Chassis components) is plate number 36B1135, which is my car's plate and is VERY close to my original. The fonts are generally a little heavier on the reproduction. But it's very good. I will probably add one to my current order with SJ :)
And continue searching out companies to have conversations with. Will certainly post if I am going to have something made.
Randy
Sea Ranch
PostPost by: nmauduit » Sat Apr 08, 2017 3:33 pm
frogeyesimon wrote:SJ Sports Cars sell the under-bonnet plate (your second picture). Not sure about the others
in case that matters, this repro plate is not very accurate (characters not lined up like the original, fonts and thickness a bit off here and there...)
S4SE 36/8198
PostPost by: Sea Ranch » Sat Apr 08, 2017 4:32 pm
Hmmm . . . I'll have to study the pic again . . . . Thanks.
Sea Ranch
PostPost by: Eric the Viking » Sat Apr 08, 2017 9:35 pm
The alternative is to contact Lotus (Andy Graham) who will supply at a price if you can supply a copy of V5 or your original plate.
Eric the Viking
First Gear
First Gear
PostPost by: Sea Ranch » Sat Apr 08, 2017 10:21 pm
I see . . . has anyone seen what Lotus supply? Can I assume it's high quality? Would they also supply the emissions plate and door jam plate (it has a vin on it as well)?
Sea Ranch
PostPost by: Eric the Viking » Sun Apr 09, 2017 9:51 am
The one they sent me is good quality and has VIN and engine number,I'm away at the moment but will try and post a pic when I return
Eric the Viking
First Gear
First Gear
