Air filter
PostPost by: davie489 » Sat Mar 18, 2017 2:05 pm
Hi there
Sorry if been covered. Having replaced my air filter today I was thinking to loose the original one as it seems bulky and stuck in front of radiator and I'm sure there's a better option.
Can anyone recommend a filter system such as K&N etc. Want to keep the box on twin Weber and just looking for the rest.
davie489
First Gear
First Gear
PostPost by: ericbushby » Sat Mar 18, 2017 3:08 pm
I fitted a conical filter on the end of the intake tubing, still in front of the radiator to collect cool air. They are readily available from K&N and on ebay.
If you are thinking of dispensing with the original type round metal box filter, you should find a ready market for it on here.
Hope this helps
Eric in Burnley
1967 S3SE DHC
PostPost by: Stevie-Heathie » Sat Mar 18, 2017 3:36 pm
Highly recommend the Clivey Boy air filter kit. I fitted one last year to my S3 and haven't looked back.
As Eric mentioned my original box was snapped up on this forum shortly after.
Best
1967 S3 SE DHC
1970 +2S (RIP - went out in a blaze of glory in 2001)
Stevie-Heathie
PostPost by: davie489 » Sat Mar 18, 2017 3:55 pm
Great thanks guys!
I've looked at his website and will be buying his kit .
Have you both got the filter fixed directly behind the grill or just up a bit to prevent getting wet etc?
Dave
davie489
First Gear
First Gear
PostPost by: ericbushby » Sat Mar 18, 2017 5:56 pm
Hi Dave,
It is quite a way back from the grill and not fixed at all. it just lies there dangling on the end of the pipe and on top of the gubbins that there is there. It weighs very little and has never got wet yet. Mind you I never go out in the rain, only come home in the rain.!
Eric in Burnley.
PostPost by: JimE » Sat Mar 18, 2017 8:43 pm
I think one would be best to refer to Miles Wilkins Twin Cam engine chapter on air filtration and silencing before making any changes. In short he says "the wrong type of air filtration or exhaust can severly restrict the power output and general running of the twin-cam engine. Jim
JimE
PostPost by: Stevie-Heathie » Sat Mar 18, 2017 11:14 pm
Mounted my Clivey boy K&N just in front of the rad, basically the same place as the original air filter. No problems with water ingress despite driving through several downpours last summer.
Only downside is the shiney bits are sometimes visible through the grille, so it's not 100% pitch black in there. I keep meaning to paint the bracketry matt black but never get around to it. Not really a problem as such.
Best
1967 S3 SE DHC
Stevie-Heathie
PostPost by: Europatc » Sun Mar 19, 2017 2:10 pm
yep would agree Clive Boy is the way to go. I've fitted his kit no problems
Europatc
PostPost by: davie489 » Thu Mar 23, 2017 7:07 am
Just an update ...
Fitted the k&n air filter from cliveyboy and discarded the old one which was tatty to say the least. It's like I have a new car! Over the moon with it .
Thanks again for the advice
Dave
davie489
First Gear
First Gear
