+2S 130/5 windscreen
yes and no........
dimensions are the same
however the glass can be different.....IIRC there are plain, tinted, sundym......
I'll offer the opinion that you're better off with a new one than someone else's second best original. They are available, there was a post in the last few weeks with a reference and the price is in line with current prices for lesser cars. Search the archives.
The rear screen was on the NLA list a few years back, don't know if that has been corrected or not.
- denicholls2
How fussy are you and how far do you want to travel?
I have a 130/5 screen which you could have for the asking. Only trouble is I'm in Scotland so couldn't be much further from you. I replaced it as the bottom corners had gone cloudy (delamination?), but perfectly usable.
Dougal.
Dougal.
- dougal9887
It was originally a Ford screen (consul classic?) and hence you can even get heated screens from time to time.
- mikealdren
My 71 +2 bonded screen surround is disgusting.
It is probably original and the clear plastic covering the chrome has had so much uv radiation it is now yellow. I have seen many with creases in the underlying chrome and have resisted repalcing mine for something else which is not perfect and costs a fortune.
Early elans with black rubber surrounds look good so I have taken measurements and a surround in black from modern ford cars would replace the chrome trim. Has anyone tried this and how does it look? Not original but possibly neater than most !
The surrounds I have looked at are the same shape and size as original chrome and the screenwould still be bonded .
- 10kph
I had not thought of this, but my understanding is that you would have to trim the fibreglass aperture return in order to fit the rubber. Also remember that a bonded screen aids the rigidity of the shell, whether Lotus went over to bonding because of this is any ones guess. If you go ahead, post some pics..
- lotusnut
both from and rear screens are available from a firm in Bromsgrove, I would have to look up the name if interested and Paul Matty has the surrounds for the bonded screen, I believe that spyder might help if you want to fit an unbounded screen David
- DavidLB
Users browsing this forum: Peter +2 and 27 guests
