2 Post Lift - raising a Plus 2
I know the question of 2 post lifts has been the subject of previous threads but I'm looking for some first hand experience on this specific question.
I've purchased a 2 post lift for my Christmas pressie and installed it over the Christmas period - just need to complete the wiring now and I'm ready to fire it up.
Simple question for those who already have one and, more specifically, use it to lift their Plus 2.
It's an obvious one but where do you position the lift pads? I intend to make some spreaders out of 19mm ply faced with closed cell foam and position then fore and aft just inboard of the cills. It's clear that the chassis will 'hang' off the body which feels kind of 'wrong' but I understand it will take it.
My other thought is to make two lateral spreader beams in timber, say 6 x 2, which will also bridge and pick up part of the chassis spine. I will make it work so no comments along the lines of 'why did you not buy a 4 post' please
So really just wanting to compare notes with folk who use a 2 post to lift and Plus 2 and any useful hints and tips.
Jon
PS: the garage was built with an 8" RC slab on 200mm Type 1 GSB and the anchor bolts are in good and tight before you any of you start!
Jon
- jono
I don't have a 2 post lift but a "QuickJack" which presents a similar problem.
What I have done is make rail out of 2x 2"x4" with foam spreader, these are close to the length of the sills on the car and mount firmly into the lift. When lifting I place these to pickup the lower front wheel arch edge and the narrow section at the rear as these area seem to be strong area of the shell.
You can see a photo at:
tool-talk-f43/scissor-lifts-t35489.html#p242320
So far I've had no issue, no funny noises and have left it up for quite a few days at a time.
My car does have some noticeable dents in the area you normally but the two post arms if your were very familiar with +2's. So I'd suggest you do do some kind of spreader.
- mbell
Hi Jon.
Like Bill I have a MaxJax 2 Post Lift.
It has large square rubber pads and I position these just inboard off the sills, close to the manual lifting points in the sills. So they are at each corner of the floor pan.
The photo shows the body in position ready to be bolted to the rolling chassis.
I use the same positions to regularly lift the assembled car, with no problems.
I should point out that I had previously fitted new reinforcing members inside the sills, as the original one were just a pile of rusted metal. So a strong structural car.
If I am working underneath the car, I try to avoid leaving the suspensions hanging for too long, by lower the car each evening. If a wheel is removed, lowering that suspension onto suitable supports.
I must say the lift has made it much easier for my aging body.
Trevor
1968 Elan +2 50/0173
TeeJay - Fourth Gear
What is the cost a maxjax 2 post lift , what is the minimal width and height of garage I need to fit one in ?
- greg40green
Google is your friend - http://www.maxjaxusa.com/buy-purchase-maxjax-car-lift/dannmar-maxjax-standard-package.html?gclid=CjwKEAiA17LDBRDElqOGq8vR7m8SJAA1AC0_x-aaox9bAgByYO05yidKryu5OaFziW6xDli3o05BCRoC1VHw_wcB
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
About $2,300 Canadian. The advantage is - bolt it down, plug in the hoses and power and away you go!!
And you can take it with you if you move. Also , your Elan will fit in an 8ft. ceiling.
Bill
Bill
Bill Rathlef
Vancouver Island, Canada
Bill - Fourth Gear
I've used my two post lift extensively to rebuild my S1, S4 and Europa twin cam. Sorry, no experience with a plus 2.
Here is a photo of lifting my S1, S4, Europa and another of the larger pads I made for the lift points.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
I have put Maxjax on my list for the new man cave. Looks like good old EBay will do the shipping from the USA approximately ?1900 GB POUNDS
http://www.ebay.co.uk/itm/TWO-POST-AUTO ... 0382533227
I had been looking at mid rise scissor lifts, but these look better.
On topic, just lift at the ends of the sills next to the wheel arches as per all the helpful photos from others
Kindest regards
Alan Thomas
Alan Thomas
