New headlights
Does anyone have recommendations for new sealed beam units for a plus 2?
It would be good to see beyond one cats eye when driving at night!
- mikebailey
Wipac Quadoptic. Get rid of sealed beams and fit halogen headlights.
http://www.wipac-aftermarket.com/uk/acatalog/Headlamps.html
I did this on my Elan and Minis back from the 70s onwards.
Pete.
http://www.petetaylor.org.uk
Pete.
I bought a set of Wipac Quadoptics for an MGB and they were poor. The beam control was awful with light scattering any which way, and after less than two years the reflectors were rusty. Since then I have bought Cibie Valeo headlamp units which take the standard H4 bulb, and have fitted them to three different cars, including my Elan. The beam control is excellent and they don't corrode. They have been on my MGBV8 for nearly eight years, used in all weather and they are still superb. The light from the Cibies is better than from my modern VW family car.
TroonSprint - Fourth Gear
The Cibie Valeo certainly get my vote...have them fitted in my Plus 2. You need to shop around though as prices differ quite a lot.
George.
George.
George McC.
1968 S4 Elan dhc.(now sold)
1973 Plus2 S130/5
1994 Elan M100 S2
1973 Plus2 S130/5
1994 Elan M100 S2
- mcclelland
anything with halogen or better will be a marked improvement on the standard single candle arrangement
You won't be disappointed with the Cibie lamps. I buy them here
http://www.europaspares.com/auto-electrical/lighting/headlamps/cibie-h4-headlamps-7-inch.html
Slightly controversial, but I have seen HID Xenon lights fitted to Elans
http://www.demon-tweeks.co.uk/performan ... ne-ballast
Slightly controversial in that they are not E approved and could result in an MOT failure unless you can successfully argue that the original equipment doesn't conform either.
Kindest regards
Alan Thomas
Alan Thomas
Has anyone tried LED headlights?
Maybe something like these -
http://www.auto-lighting.co.uk/product- ... chips.html
- KevJ+2
KevJ+2 wrote:Has anyone tried LED headlights?
I tried LED bulbs in the spots and they were hopeless. I had to get out to ensure they were actually on!
- vincereynard
There is a feature in Classic Car weekly this week that covers LED bulbs and totally advises against them for use as replacement bulbs for classics. Apparently you need the complete light unit that is designed for use with LED because standard lenses and reflectors are incompatible and result in below acceptable light output.
HID xenon light up the road very nicely, just got to be careful with that MOT man...... A friend was asked if He had fitted blue halogens.... "yes that's right" He said.... passes every year.
Kindest regards
Alan Thomas
Alan Thomas
Spyder fan wrote:There is a feature in Classic Car weekly this week that covers LED bulbs and totally advises against them for use as replacement bulbs for classics. Apparently you need the complete light unit that is designed for use with LED because standard lenses and reflectors are incompatible and result in below acceptable light output.
And why do you think retro fitted HID's are an MOT failure ? It's because like LED's, the whole system is designed around the HID bulbs. Without the correct reflectors & lenses you may well be able to see into the middle of next week, but you will likely be dazzling every driver that comes towards you ! On cars fitted with HID lights, even the headlight washer system is part of the MOT, as the build up of road grime upsets the beam pattern sufficiently to cause dazzling to oncoming drivers. They also need to have automatic self levelling built in to compensate for any weight in the boot, full or empty fuel tanks etc, or you're back to dazzling everyone. There's much more to them than meets the eye, which is why these kits state for off road or show use only.
My vote would go to Cibies, like Wipacs, a simple inexpensive conversion with quite an improvement over sealed beams. I have had Wipacs in the past, & they were good, but have had issues with the reflectors going dull or rusty in too short a time. Also had the glass separate from the reflector on one set. The Cibies in my +2 have been there for years now & are still as good as new, for that reason I have to rate them above the Wipacs.
Regards, Tim
- Orsom Weels
Tim,
I did say they were controversial, but they do work. Unlike the LED bulbs which don't give sufficient light output unless they are coupled with designed for LED use lenses and reflectors. Apparently people have been replacing incandescent stop light, tail light or indicator bulbs with LED bulbs and realising like Vince that the light output is well below par.
When did you last load your Elan with 2 sacks of cement and the weekly shop in the boot/trunk? Normally our cars have a problem with the headlamp aim being too low, it would take a large amount of luggage probably more than you could fit in an Elan to raise the nose sufficiently to dazzle oncoming traffic.
Hypothetical and interesting, there's lots of clever people on here that could design a workaround for the MOT.
Kindest regards
Alan Thomas
Alan Thomas
