Removing side impact frames
The Spyder ones should go in and out with the rear struts in place, but the original Lotus items do require the struts to be removed.
Are they side impact bars? At only a few inches off the ground I don't think they would stop much in the way of a side impact, unless the car hitting you had a snow plough on the front. I believe they are just there to strengthen up the shell a little, which is very floppy without them!
They also provide the seat belt mounting point.
- ianthomson72
ianthomson72 wrote:They also provide the seat belt mounting point.
Really? I thought those were on the spaceframe around the door aperture like the two seater.
We are talking +2s, and mine fell out the bottom OF THE CAR, unlike Simon's which must have required medical attention.
Meg
CBUEB1771 wrote:Quart Meg Miles wrote:Really? I thought those were on the spaceframe around the door aperture like the two seater.
The +2 does not have the lattice structure which is bonded into Elan shells.
Thanks Russ,
My ignorance, but it must be why I never had to touch it on my S130, everything else went wrong! As the sill members were oxide what was my seat belt held on by?
Meg
Fiberglass, rust and a prayer.
"My my, hey hey... It's better to burn out than it is to rust."
Ah, life on the edge.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Steve, you can take them OUT either front or rear. Just use your sawzall, or a hacksaw, and cut them off, chunk at a time as you pull them out. No problem.
Which way to get new ones back IN is a different question. If you're working toward a new paint job/respray, then I would suggest:
- out and back in from the rear
- jack car and remove one rear wheel. Keep other wheels on ground
- put jack under rear suspension and lift rear hub/compress suspension
- now your hub is mostly out of the path of the sill as it comes out/goes back in.
- the final bit of clearance comes from flexing the fiberglass outer sill out to allow the sill member to go into place on a bit of an angle.
Honestly, mine were not a problem doing it this way. However, if the paint on my car was really good, I might worry about gel coat cracks when flexing the outer sill panel.
One final tip/reminder: Keep the doors closed, keep the car level, with normal "weight" on all four corners. The rear hub on the side you're working on should be jacked enough to approximate normal ride height. This is so the body is not twisted during the process. Work on one side at a time. Completely install the new member before moving over to other side.
Randy
Randy
Randy,
Thanks for that,
Mine look perfect so don't want to saw them.
I'm thinking of building a track car and obviously the plus2 is very heavy in comparison to the 2 seater so looking at options to reduce weight.
It will need a roll cage so that will also have to replace the side frames - haven't started yet just looking at it
Thanks for that,
- patrics
On both my Plus 2's most of the sill members fell out of the sills when I opened up the bottom joint; the rest came out with the vacuum cleaner.......
Visit me on matthewvale.com
Matt Elan - Fourth Gear
