Mystery engine
>PS is it wrong to enjoy the popping and banging on the overrun!?
Mine always does that.
Probably bad for the environment.
The real identity number of an Elan is the UNIT NUMBER on the VIN plate inside the engine compartment fastened to the fibreglass usually on top of the left hand foot compartment. This is what you should always use in dealing with DVLA.
The plate may also show an engine number, but often that is blank.
The chassis (subframe) number as mentioned above is usually stamped into the chassis on the flat bit near the exhaust down pipes. See lotus-chassis-f36/where-the-chassis-number-stamped-elan-1600-t26938.html#p179921
If you change the subframe don't bother to inform the DVLA! It will cause bereaucratic nonsense. Far simpler to buy some letter punches and punch the unit number onto the subframe.
The engine (block) number is on the block stamped into a flattish (but sloping) at top of the right-side engine mount
billwill wrote:>PS is it wrong to enjoy the popping and banging on the overrun!?
I altered my ECU map settings to get the pops and crackles on the overrun. One of the injectors gives a couple of squirts below 2000 rpm when the throttle is closed and shuts off at 1200, extremely antisocial but it 's a great soundtrack.
Kindest regards
Alan Thomas
Alan Thomas
If you're over 60 going on 18 it's fine..
Hi all,
Just by way of postscript, chassis number and engine number have been confirmed as follows:
Chassis: 50/1151 (so very close to yours, Kev!)
Engine: H17590 (and then a "B" or a "3" maybe).
Not sure if there are any records which would show whether these are a match, but at least they tally with what the DVLA have.
Thanks for all your assistance.
Al
Al
- alanpearl
the list I have shows that to be the correct engine
the list says
50/1151
eng No H17590B
4 Speed box
Built on 28th Nov 1968
not saying the list I have is correct....but seems about right from your description
the list says
50/1151
eng No H17590B
4 Speed box
as a cross reference.....
Kev youre 50/1153
so my list says H17533B (Engine No)
4 speed box
Built 27th Nov 68.......
is it anywhere near?.....
Kev youre 50/1153
4 speed box
G......yes that's exactly right.
Al, your engine number is only 57 after mine! Amazing, given that Lotus numbers are all over the place!
It might be of interest to you to see what the body number is. It should be within a small rectangle at the back of the engine bay in the corner, near the solenoid.
Kev.
Kev.
- KevJ+2
theelanman wrote:found it.....
if your car was pre 50/0928 (chassis No) then it should be a mechanical fan.....
if post 50/0928 (chassis No) then that's the switch to the electric fan
My Service Parts List shows the mechanical fan on all +2 production with the supplement of the electric fan added after 50/0928. My 1971 +2S always had both mechanical and electrical fans.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771 wrote:theelanman wrote:found it.....
interesting......
Ive never seen a UK version with both......
maybe owners took them off the water pump in order to extend its life.......
I know mine came with the mechanical one on the water pump and I took it off and replaced it with an electric one infront of the rad for this reason as I had already had water pump fan issues on my other elan.......
