Bad backfire
HI all, after 32 years my 1968 +2 is back on the road but as you pull away it really back fires. I have done all the usual plugs, leads, cap, coil, timing. Carbs rebuilt still the same, I have a new luminition optronic which I have sent back to be tested, I have also checked all the earths. It starts well and ticks over perfect. as you can see Im a newby here, Ive been reading this site for a few weeks now and I must say how helpfull eveyone is.
ROY.
ROY.
- royrender1
Roy,
I'd check for vacuum leaks, likely candidates are the "O" rings in the carb mountings or probably very likely cracked or leaking plumbing on the headlamp vacuum system.
Carb balancing and vacuum leaks would a good place to start
Check also
compression
valve timing (you got the two little notches in the sprockets pointing nicely to eachother at TDC)
coil- an overheating coil will fail you under load
quality of fuel - if it has been off the road for that long......
charge voltage- the electronic ignition can throw some gremlins in your joy if it does not get high enough voltage
good luck, you will find out what is wrong I am sure.
Check also
compression
Leif
1968 +2 Wedgewood blue
Houston, TX
Houston, TX
- leifanten
Check the fuel supply - restriction on fuel hose (collapsed?), float height (if Webers), fuel pump pressure etc. My +2 had similar symptoms - fine at tickover, but started to misfire & backfire as revs increased or you put any load on the engine, such as pulling away). I traced the problem to a kink in the fuel hose, restricting the flow rate to the carbs. If you have Webers, keep a screwdriver in the car ready to whip off the carb tops and see how much fuel is in the bowls after the car mis-behaves.
Worth finding a quiet stretch or road to conduct a test, where you can stop and carry out the examination as above without being flattened..
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
