What is this for?
It is the rail for the corner rubber door seal.
Remove them and keep them as a patern for the new seal. The ruber seal should be 2 inches longer towards the front of the car if you want it to impeed some of the rain to get in to the car via the front top of the door.
Best
Carlos
Best
Carlos
http://yourgarage.nbc.com/cars/Lotus1970?vehicleID=112804
BUY GAS WITHOUT ETHANOL: http://www.pure-gas.org/
Carlos A - Second Gear
Jon,
Is this another difference between cars of differing ages? My car doesn't seem to have it? Were they only fitted on early cars and if so, what changed so that they were no longer needed?
- mikealdren
Will try and do this for you tomorrow Jon.
Believe it or not I still have mne
Peter
Peter
'73 +2S 130/5
'73 +2S 130/5
peterako - Fourth Gear
You can buy a weather rubber seal in a car parts store and glue it with high quality glue over the metal rail or remove it and simply glue the seal to the body. Remember: you need a longer piece than the original (two inches more towards the front of the car) if you want that thing to keep at least some of the rain out.
I am traveling (in Brazil) until the 14th so I will not be able to take a picture until then.
Best
Carlos A.
Best
Carlos A.
My reward for seeing the question in this post and thinking "perhaps I can help" - this piece is one (two) of a very few things left in the rebuild for which I have (had) no idea what they were for. I had a vague memory of a tacky, ineffective piece of weather seal in that spot but had never seen the metal strip.
Thank you very much!
Now to find the material...
Keith
Keith
- kcrossle
I would also benefit from seeing a pic of the profile and how it is installed. My PO had installed something completely different on the door, and I had assumed it was the stock set-up.
I bought two seals from Susan Miller last November, but I had no idea how they were installed or what they should look like! When I ordered them, she mentioned "the OE secondary seals are obsolete, but I have something similar which would do". I can post a picture of what she sent once I see the original to compare to; may help some with finding a substitute locally.
Stu
1969 Plus 2 Federal LHD
