Mystery Part
So; I finally fired up the plus two for the first time this weekend, so i am starting to see some light at the end of what has been a somewhat longish tunnel.
now the best part... sorting out all the "extra bits"
any guesses where the following item goes? it looks like some sort of heat shield.
Jan
1963 23B
1969 Elan + 2
1973 Europa JPS Special
2004 Prep'ed Lotus Exige
1963 23B
1969 Elan + 2
Over Steer - Second Gear
Looks like it's aluminium and homemade, does it fit as an exhaust heat shield anywhere?
- mikealdren
Looks like you have your answer so perhaps you will forgive me for hijacking this thread slightly. Can someone take a look under Parts Wanted header +2 Pedal Box.
I have posted a picture of a pedal box but not sure what it's off - there is a black plastic electrical switch of some kind sticking out of the top.
Your pointers would be appreciated.
elanfan1 - Coveted Fifth Gear
thanks for the reply guys, it makes sense now (radio shield on bell housing).
dunno about the switch you're mentioning Steve, maybe you could post a pic? the most obvious thing that pops to mind is a hydraulic fluid level sender/warning light.
Jan
1963 23B
1969 Elan + 2
1963 23B
1969 Elan + 2
over steer, that is the radio suppressor plate fitted to some (it would seem) cars, as for the pedal box with the switch built into it, my s130 had this set up for the brake light switch, earlier cars had the brake switch in the copper brake line on a brass T
- tower of strength
Users browsing this forum: The Veg and 21 guests
