Need some advice/opinions
Well I've checked the serial number and the one I need (LR18221) is not on the box. There is another number which is also on the tag that is attached to the air valve pipe (4258 221). So I rang Delphi and they checked this number which turns out to be correct. Hurrah!
Don't know why they have two different numbering systems but is anyone else is confused this is the way to check (assuming the tag is still attached).
Incidentally, the installation guide I got off the net says that the vacuum hose should be installed with a loop dropping down below the level of the servo and inlet manifold, like a 'U' trap to prevent petrol vapour getting into the servo. I've never seen one installed like this, anyone done it?
I have not followed this thread from the start but picked up on your question.
I did this with the very same unit on my S4. I picked up an additional valve from Stoneliegh of another Lotus for ?1.50.
I did exatly what is said as I had a servo fail. ?180 and 18 months after the refurb'. Also brake fluid in the inlet manifold burning away my master cylinder level. Petrol got at the Diaphram. Hence the two non return valves and the loop and "Tee" off upwards. It should not happen again. I left quite loop in the nose.
miked - Coveted Fifth Gear
Robbie
I picked up a new old stock servo valve from C Neil on one of their clear outs. I cant recall what it was off but it was for a Lotus servo system. No info' on it now. They will have a rating but to be honest I did not check. Bit naughty, but I figured if it failed I would still have the other one and it would more likely fail to seat than anything else. The servo does have one on but the instructions say that on high performance engines you should fit a second one. I fitted this and it works fine.
Just for reference I found that servo at a Moggie 1000 site for ?112 before VAT. (about a year ago) Have seen the same one at ?240 in the Burton cat'.
Why dont you contact the brake servo manufacturer.
Thanks again Mike,
I was talking to Paul Matty/s and they said that some Plus2's were fitted with a valve in the metal portion of the vacuum pipe. I'll have to do some investigation into this.
In the meantime I'll fit the servo anyway - I imagine the just valve in the servo will be ok for a bit.
Robbie
Robbie
Hi There
The chap at Norton servos is still in business for sure. I spoke to him last week.
Berni
Berni
berni29 - Fourth Gear
