Need some advice/opinions
I have a suspected Servo problem on my Plus 2. It was fitted with a Lockheed replacement some years ago (6 or 7 from what I can gather) and the car has only covered around 500 miles since.
After replacing the master cylinder and a new front caliper recently I had a lot of trouble getting the air out of the system. This seems to be ok now as I get a reasonably firm pedal. However, once I start the engine the pedal goes mushy with lots of travel and a small amount of creep. I've done the tests in the manual and the servo operates (hisses) on brake application with the engine running and after 2 minutes of switch off.
So I suspect the seals have gone in the hydraulic bit of the servo (possibly due to the lay-up). Anyone agree with me here?
Next point; I've rang around for a rebuild kit and a coulple of places quoted me about 60 quid. Then I rang a place called J&L Spares (Brake servo specialists) and the man told me with a sigh "there are so many places selling these Lockheed servo's and they all seem to be a different spec. The castings all have the same part number on them but internally, there are a number of different piston sizes..."
So he asked me to dissmantle and measure both the pistons and get back to him for the seals, which should be about ?25.00.
So questions are:
1. Does the servo sound suspect?
2. If I bought and off the shelf kit, what are the chances of it being the wrong size (in other words has anyone heard of there being various sizes of servo specified for the Plus 2)?
Sorry for the rambling post, I did get the part number for the servo kit from Delphi, but in the light of what this guy is telling me I can't be sure that whoever fitted the servo bought the one that the kit fits...
Thanks in advance
Robbie
So questions are:
Thanks in advance
Robbie
The Lockheed servo needs to be mounted correctly per the Lockheed instructions to ensure that it does not trap air. IIRC it needs to have the hydraulic outlet higher than the inlet which is not always easy to achieve in the plus 2 bay unless you make appropriate brakets.
Two other things that can affect pedal feel.
Flexi hoses (They are pretty long and distort under braking as the try to starighten) and body flex around the pedal box. My +2 has always had long pedal travel and a slight questionable feel despite multiple master cylinders, servos and caliper rebuilds over 23 years plus aeroquip hoses.
Stu
Stu
schroeder - Second Gear
Hi Robbie...it does sound like a servo problem, but if it is the seals that have gone, what else isn't right in there? I've overhauled servos, calipers and master cylinders in the past, but with patchy results on servos in particular. I now hand my stuff over to a specialist who goes through the whole thing, checks every component, re-plates the casing and hands back what is effectively a brand new unit that has been hand built rather than mass produced. I figure if there's one area that extra cost can be justified it's the brakes.
I use Classicar Automotive in Cheshire, who specialise in Elans. They can also rebuild the original Girling servos if you can get one. Always had great service and a product that lasts.
Hi.
I also used Classicar Automotive. Mine's an original, and it came back looking brand new. Very pleased with the result. However, they did take some time to overhaul it as parts were hard to source (a few months) so if you're doinig this for a car that's on the road and not mid restoration I would discuss options with them first - I think their part exchange units cost the same - avoids the wait.
Is it worth trying to bypass the servo if you're not sure that's the cause of the problem - it's inline, so can you get some adapters and bypass it just to test the rest of the system?
Sean.
Sean.
- alaric
Thanks Mark, Sean,
I called Classic-car and they said to rebuild it was almost the same price as a new one (?145.00)! Although I have found an ebay shop selling new ones at a discount at the moment - ?115.00
I was hoping that, as the servo has had only 500 miles use it wouldn't be worn, just that the seals had gone off due to it's prolonged lay-up (like the master cylinder).
I'd like to get hold of a Girling but the ones that show up on ebay are generally past it by the look of them.
As a matter of interest I do not have a servo on my 69 +2 it was taken off long time ogo by the PO. My brakes are very firm little travel in the pedal and the amount of pressure to stop at high speed is not much more then if their was a servo. The +2 is very light and if correctly set up it does not really need a servo.
Geoff Minors
1969 Lotus Elan +2
1972 MGB (being restored)
1981 Fiat X19
1973 Norton 850 Commando
1969 Lotus Elan +2
1981 Fiat X19
gsminors - Second Gear
Thanks Geoff
I did consider that but I like the servo assistance.
I decided, partly encouraged by Mark, to get a new one. Especially as there are rumours of them not being in production for much longer....
Cheers eveyone for your input.
Robbie
Robbie
gsminors wrote:As a matter of interest I do not have a servo on my 69 +2 it was taken off long time ogo by the PO. My brakes are very firm little travel in the pedal and the amount of pressure to stop at high speed is not much more then if their was a servo. The +2 is very light and if correctly set up it does not really need a servo.
I removed the servo from my +2S many years ago to "add lightness" etc. I tried hard to make it work including going to the smallest bore master cylinder available (5/8"). I could never get the pedal force down to an acceptable level. I had disturbing amounts of flexure in the scuttle where the pedal box is mounted. I put the servo back in and have never looked back.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Russ...as the owner of an Elite would it be fair to say that you're a little more aware of fibreglass structural failure than the average Elan owner?
You are of course right, it's not uncommon for the pedals / pedal box to break away from the shell, particularly in this often brake fluid, oil and petrol soaked area.
Although this is an Elan forum, I think it's quite justified to have a picture up of the Elan father....go on Russ, show us what must be one of the most beautiful cars every made.
Elanintheforest wrote:Russ...as the owner of an Elite would it be fair to say that you're a little more aware of fibreglass structural failure than the average Elan owner?
Mark,
I suppose you are correct about this. I have been in some raging debates within the Elite community about servos. Even some Elitists don't seem to be bothered by the sound of cracking fiberglass. Unfortunately my Elite is in somewhat less than photogenic state, so at your invitation I will post one of my favorite images and something close to what my end product will be.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Fantastic picture Russ. Do you have to have front plates in Boston? They let us off in the UK still with the digits in the grille on the Elite and Elan, but most European countries and Japan seem to insist on great big plates on the front, which doesn't do much for the car. White with the Silver roof does look very pretty, but Primrose with a Red interior is the colour for me. I've gone all weak thinking about it.
There's a bit of an Elite thing going on in 'Free Parking...What was that Poster?' thread right now...I'm sure you could have answered the questions!
Elanintheforest wrote:Do you have to have front plates in Boston? Mark
We have a fascinating system in the US with each state having its own vehicle registration, inspection and insurance requirements. Imagine Sussex and Surrey having different plates and MOT requirements. In Massachusetts we had rear plates only for many years but more recently returned to a front and rear system. The earlier rear-only plates are still legal, being "grandfathered". The two systems are readily distinguished by differing colors for the letters and numbers. My +2S has the old rear-only plate which I hope to carry to my grave. My Elite is relatively new to me and undergoing a top-to-bottom restoration and I have never registered it for the road. I am probably two years from that event. So the Elite will likely have two plates and I am sketching a system of brackets with quick-release pins such that I can quickly attach and detach the front plate. Perhaps over the weekend I will photograph both the +2S and the Elite nestled in the garage and post that. The +2S is "down" for the dreaded water pump repair. Well, I certainly have rattled on off-topic. Hopefully I have not annoyed anyone.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Users browsing this forum: smiths everest and 19 guests
