Stoneleigh 12th Nov...
Doug
Yes and Yes....
I'll be there (VWW 965F white Plus2) with the bits in the boot to convert to efi (Mondeo edis) and will be back at the car at 12:00...
Yes and Yes....
This year their featured car is the Elan.
How many of you guys are planning to attend?
?1 off tickets if you order them now
Beware of the Illuminati
I'm going in my +2 what ever the weather !
Could we have a table in the restaurant labled Lotuselan.net like there was at Donington ? It was nice putting faces to cars and names.
Matt
Matt
1967 Elan S3
1970 Elan S4 Sprint
1972 Europa TC
1973 Elan +2 s130/5
1978 Esprit S1
1981 Esprit S2.2
1970 Elan S4 Sprint
1972 Europa TC
1973 Elan +2 s130/5
1978 Esprit S1
1981 Esprit S2.2
- Matt
Jason
Mk1 spyder springs?
Are they not just standard 2.5" springs?
Mk1 spyder springs?
I don't know,
I asked Spyder and they said they did not keep records that go that far back so I need to upgrade to the MK2 suspension
If I was using the car every day I would quite happily spend the ?1,000 +VAT, but at the moment I have other priorities. So am looking for the cheap option
I would imagine that the spring rate of the originals would be ok on the Spyder chassis as the weight of the car would not have changed that much? So I just need to find that.
Jason
Jason
Jason1 - Coveted Fifth Gear
Hi Jason,
Would it be cheaper to convert back to original spec on the suspension. Bit's from Stonleigh perhaps?
I'm not familiar with the spyder set up in detail so I guess it depends on how much of the orig bits are missing. Just a thought anyway.
Btw. I know what you mean about fitting solid driveshafts - I didn't find it easy either
The shocks are Koni unitsso if they are standard off the shelf coil over dampers, when I finally manage to get the springs off I should be able to order the new Koni shocks.
The standard springs are 16 inches and rated 93 lbs/in, so I just need to measure the springs and check they are the same length as standard
Getting there
Getting there
Hmmm, I'm in London with my old father that weekend. What better way to spend a sunday?
Any info, adress, map, web-site, entrace fee etc? How to get there by train from London?
Bjorn-Anders, Norway
'95 Caterham Seven Roadsport
'02 Elise Supercharged
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
Life is too short to drive boring cars
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
b-havers - Third Gear
Bjorn,
Check the website given below. They should be able to give you the information you need.
Tickets ?6 or ?5 when pre-booked.
http://www.clublotus.co.uk/nationalevents.html
I hope to be there in my +2. I can't believe it has been so trouble free since I got back from classic le Mans! I even had to rescue my brother the other day when his latest car ( 4.5 lightweight TVR Cerbera - 202 mph) broke down in norfolk. Lotus 1 - TVR 0 !
- chrishewett
