+2 S130/5
The sunny UK weather reminded me to start the car and check it out for a drive this weekend. Anyhow the car will crank, but wont start. There is no spark at the plugs, I've checked the points and I had a spare coild/ baalast resistor which I swapped and still no joy. Can you please provide advise on what to check, in what order to get to the bottom of the problem?
- SteveMaddison
Try disconnecting condensor if you get a spark this way replace condesor
- elansprint
Hi There
Probably best to look up an ignition fault finding guide on the net. In addition to the above though I would give a quick clean to the spade connections to the coil and solenoid etc.
Good luck
Berni
Good luck
Berni
berni29 - Fourth Gear
I've replaced the points, checked the distributor cap and checked connections. I do have power to the coil. I'll check the condensor next. I can't see a short anywhere, so I'm pinning my hopes on this.
- SteveMaddison
I had a similar problem a few months ago and it turned out to be grounded points because the screw was a little too tight. I suspect you haven't opened up the cap in your sleep during the winter to tighten the points nut, but I was able to determine the issue with a multi-meter and checking resistance between each step of the connections.
Good luck, and I hope the good weather doesn't go to waste!
1970 Lotus Elan +2, 1991 Lotus Elan, 2006 Lotus Elise, all for sale.
Hegg - Second Gear
