Seven S2 rear brake piston to back plate
Apologies for being off topic, I’m rebuilding rear brakes on our s2 seven, it’s still fitted with standard 10 axle etc. I think same system is used on Europa’s.
Can anyone share tips for assembly of the cylinder to back plate, in particular the clips that secure the piston. Ive not removed the axle so working space is tight, I’m replacing all parts including clips and rubber seal. I’ve assembled all off the car and appears to fit. On the car I’m unable to get the thicker clip to slide in fully.
All tips and suggestions welcomed.
Vaughan
Vaughan
- vstibbard
Thanks, yes the spring steel retainer #5 has dimples that locate into the steel retaining clip #8. All looks simple but sliding them into the rubber seal #6 is proving difficult. I’m wondering if new brake cylinder body is oversized as old parts came apart easily. I’ve been tapping with drift to no avail. I’ll strip it and measure it up and try again with rubber grease this time.
Not helped by no room to see without removing the axle so it’s all by touch.
Vaughan
- vstibbard
vaughan,
It's been too long since to remember specifics, but I do seem to recall it being tight. I'm reasonably certain I did use some rubber grease. I'll look back at pictures and see if that jiggles any useful memories into focus.
Henry
Henry
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
It looks like a very similar set up to the Mk1 Escort. The clip can be slid off by using a screwdriver and the side of the cylinder for leverage. One half of the clip is sprung and the other isn’t. It’s the half that is sprung that you need to slide off first using the screwdriver. Once that is removed you can slide the other half off by hand: You need to detach the handbrake cable and remove the rubber boot covering the clip first and similarly when refitting the boot goes on last after the clip is fitted and before reconnecting the handbrake cable
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thanks All, tge light came on, I’ve followed the image in parts manual and fitted the clips to secure the rubber seal as there’s perfectly shaped depression. With clips under this seal it should be very straight forward.
Many thanks to this great forum. Keen to get out in Sydney’s beautiful spring weather.
Vaughan
Vaughan
- vstibbard
Users browsing this forum: RichardS and 6 guests
