Lotus Elan
VIN number, how to find.
PostPost by: berni29 » Thu Mar 09, 2023 11:08 pm
Hi There
For my 1968 Lotus Elan +2 reg number DMB 258F (which is in bits for many many years), I have misplaced both my old V5 and the body plate. I did want to apply for a new V5 but will need the VIN number. Is there any way I can find out the information I need?
Many thanks
Berni
berni29
PostPost by: billwill » Thu Mar 09, 2023 11:55 pm
It should be on a LOTUS plate in the engine compartment.
The plate specifying obsolete oils etc,etc.
PostPost by: pharriso » Fri Mar 10, 2023 12:40 am
berni29 wrote: I have misplaced both my old V5 and the body plate.
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: StressCraxx » Fri Mar 10, 2023 5:09 am
Look at the top flange of the chassis, just below the engine thermostat housing, above the motor mount. The VIN should be stamped on the chassis. You may have to wipe away the grime to see it.
StressCraxx
PostPost by: Gordon Sauer » Fri Mar 10, 2023 5:20 am
If it’s still in a lot of bits, on the inside of the doors, inside the headlight pods, and on the roof under the headliner, usually seen also, Gordon
Gordon Sauer
PostPost by: trw99 » Fri Mar 10, 2023 7:06 am
Is your engine original to the car?
If so, get the engine No from the intake side engine mount boss and I can track it back from there, hopefully.
PostPost by: Spyder fan » Fri Mar 10, 2023 8:20 am
It’s on the DVLA database under its reg number.
3A137964-7B88-4441-A72A-285AA8EEB87B.png and
Kindest regards
Alan Thomas
Spyder fan
PostPost by: Billelan » Fri Mar 10, 2023 9:00 am
I was in a very similar position with my S4. I would enlist the help of Alan Morgan of Club Lotus. This is a service you will need to pay for but certainly worth it in the long run. Certainly do not contact DVLA until you have spoken to Alan.
If the chassis is original then the number will be stamped on the top flange near the exhaust mounting. If not, I would start by looking for the engine number and see if this can matched up to a chassis number held on record.
Billelan
First Gear
First Gear
PostPost by: elanfan1 » Fri Mar 10, 2023 9:26 am
IF the car is registered at the DVLA at your address then it’s a case of just applying for a duplicate V5. If it’s not you should just be able to do a change of keeper.
If the chassis is original the no. will be there (as above) also Tim will get you the no. if the engine is original.
Silence is Guildern; Duct Tape is Silver
PostPost by: berni29 » Fri Mar 10, 2023 9:57 am
Hi Guys
Thank you for all the suggestions.
The chassis I threw a long time ago. It was so badly cracked and rusty it scared the bejeezus out of me.
The body identification plate was removed from the body and placed inside the folded V5, and is secreted lord knows where.
The body itself along with all the panels have been painted inside so the body number is no longer visible.
The car is registered to me at my home address so no problem there.
If I did a change of keeper would someone still not need the VIN somewhere along the line?
I will not be contacting the DVLA for help! That is akin to inviting the vampire in for a good meal.
Original engine is long gone. I almost cannot remember what happened to it.
Looks like I will contact Alan Morgan of Club Lotus after another search in the house/garage/sheds/boxes of parts.
Many thanks again!
Berni
berni29
PostPost by: Billelan » Fri Mar 10, 2023 10:14 am
I don’t know about +2 but I found my S4 chassis (VIN) number hand written on the top of the glovebox.
Billelan
First Gear
First Gear
PostPost by: ericbushby » Fri Mar 10, 2023 11:33 am
Hi All,
I understood that the number found on the bulkhead and inside of the doors, roof etc. is the body number and this bears no direct relationship to the unit number which is engraved on the `VIN` plate and chassis.
Certainly mine differs by about 600.
If I use my body number as a VIN No. and look it up on Elan Registry that car is in Canada and been owned and stored for nearly 40 years.
I have the full list of owners from build date and there are no gaps where it could have been exported.
Be careful that you do not use the wrong number. If that number relates to a different car the DVLA will throw a fit.
Eric in Burnley
1967 S3SE DHC
PostPost by: Bud English » Fri Mar 10, 2023 7:43 pm
The only place that the "body" number appears on my car is where it's molded into the body in the upper right corner of the firewall. All of the chalk, marker, pencil and engraved numbers on the roof, light pods, glove box, etc are the chassis number. Of course that's only a record of one out of one. Your car may differ. It's a Lotus. :wink:
Bud
1970 +2S Fed 0053N
Bud English
PostPost by: billwill » Sun Mar 12, 2023 1:15 am
The number on the chassis is not necessarily the VIN number.
Mine wasn't the same.
As far as I know the VIN on the plate is the "MASTER" identification of the car. So do your utmost to find it.
PostPost by: GLB » Sun Mar 12, 2023 1:35 am
On my federal 1970 *2S the last four numbers of the VIN were engraved on the inside of the doors with about a 1/8 diameter ball burr or so it appears, crayoned on the inside of the roof with some other notes and written on the back of the glove box and signed by Paul. Gary
GLB
Next
