Brake fluid tester (Lidl UK)
In case it's of interest, Lidl currently have on sale brake fluid testers for £6.99:
https://www.lidl.co.uk/p/car-accessorie ... ter/p54457
I last changed my brake and clutch fluid just over 2.5 years ago, and the water content was showing as > 4%...
draenog - Third Gear
pharriso wrote:Which brings up the question "What's an acceptable amount of moisture content?"
Less than 2%. 0% is ideal. Moisture = corrosion.
StressCraxx wrote:pharriso wrote:Which brings up the question "What's an acceptable amount of moisture content?"
also moisture boils when getting hot (100°C vs 250-300 or even more for racing fluid), causing brake fade during spirited driving...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Dreanog.
Many thanks, purchased mine today , need to change my brake fluid.....
Thank you for the heads up! To Lidl I go tomorrow........
Berni
Berni
berni29 - Fourth Gear
Just change the fluid completely every 2-3 years (Porsche and BMW both say 2) and you'll not need the tester. And your brakes will be happier. I like happy brakes.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
bitsobrits wrote:Just change the fluid completely every 2-3 years (Porsche and BMW both say 2) and you'll not need the tester. And your brakes will be happier. I like happy brakes.
Now I'm a sucker for buying the tools and toys, but this is what I do as well. The issue I see with brake fluid testers is that unless you bleed the brakes and test what comes out of the caliper, you're only testing the m/cylinder reservoir fluid.
All well & good but this is the most likely area to have a high water level because it breathes to the atmosphere. It's hard to see how moisture gets much further into the system. The fluid down the lines and behind the caliper piston will be different because it doesn't flow around the circuit until you bleed some out. Some will go from the reservoir to the m/cylinder as the pads wear so IMO changing fluid protects that part of the system.
Because my cars don't do a great mileage or wear through pads I tend to go with a 2 or 3 year interval. If it's been a while since doing any work and I need to bleed the brakes then I'll empty the m/cylinder & replace the lot before bleeding. It's cheap insurance.
UAB807F - Fourth Gear
UAB807F wrote:The issue I see with brake fluid testers is that unless you bleed the brakes and test what comes out of the caliper, you're only testing the m/cylinder reservoir fluid.
All well & good but this is the most likely area to have a high water level because it breathes to the atmosphere. It's hard to see how moisture gets much further into the system. .............
So what you're saying is that you are testing worst case... that is fine!
Will try to pick one up this weekend when I visit the UK.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Good luck getting it to fit between the Weber carbs on a Sprint ! Its a bit of a tight squeeze……..
My 1 year old fluid still came out at less than 1 %
'72 Sprint
'72 Sprint
- richardcox_lotus
richardcox_lotus wrote:Good luck getting it to fit between the Weber carbs on a Sprint ! Its a bit of a tight squeeze……..
That’s the advantage of lhd!
I guess with rhd you could extract some brake fluid with a turkey baster?
P.s. don’t tell the wife!
Phil Harrison
