Headlight knob metal clip wanted
PostPost by: Evante » Sat Oct 02, 2021 1:35 pm
Does anyone know where to source the metal clip that holds the headlight knob on for an S4 or Sprint? The pic below shows the type of clip I mean.
Knob clip.JPG and
Jay S.
1972 Federal Sprint, Colorado Orange/White
2005 Elise, sold
1988 Evante 140TC, sold
Evante
PostPost by: tedtaylor » Sun Oct 03, 2021 11:18 pm
looks easy enough to fabricate one.
TED
tedtaylor
PostPost by: RAJ2628 » Mon Oct 04, 2021 1:05 pm
These springs are not that easy to find or make, but I had some made by Lancashire Springs a while ago. They were made to suit the headlight vacuum switch but it looks similar to your photo. Lancashire springs are not in business and these tiny springs are not cheap. The wider base is 6mm × 13mm - the thinner top piece adds 2.5mm to the base as it curves around. The return top spring is 3.6mm wide x 12.6mm long. The hole in the wider base leg is 3.5mm. Let me know if it is suitable.
RAJ2628
PostPost by: Evante » Mon Oct 04, 2021 5:30 pm
RAJ2628
I will check the dimensions and let you know.
Thank you!
JAS
Jay S.
2005 Elise, sold
Evante
PostPost by: billwill » Tue Oct 05, 2021 1:30 pm
If you have a real Clock Repair shop in your vicinity, the kind where a craftsman could make pivots, gears & springs etc during repairs (!) having such a person make a flat spring with a button like that should be dead easy.
(!) Like the bloke on the TV program "The Repair Shop".
PostPost by: nomad » Fri Oct 08, 2021 2:07 pm
Not difficult to make one yourself. If you have a heat source and files.
Kurt
nomad
