S4 performance
Pretty fast.
What is the spec on your S4? Not stock I suppose.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Do you recommend the Dragy? Things you like and don't like?
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
I did download a couple of mobile phone apps for performance testing but found them to be utterly useless, probably due to the slow gps refresh rate?
I did not want to spend hundreds on an all out lap timer device, just something to see if any tweaks are an improvement or not. Research showed the dragy to be very accurate and easy to use with the app connection via Bluetooth.
There are lots of pre-set parameters and you can add your own like 30-70 mph. It also recognises the location so you can’t cheat by driving downhill.
The blurb says they are working on other things to load onto it but, I haven’t seen anything yet.
Does show how much time is wasted changing gear, especially with a 5 speed that can’t be slammed into second! Someone needs to build a dual clutch
- vxah
