Brand New Lotus Twin Cam Engine From 1964
The reason you don't see locknuts of any type in most engines is because the fasteners are tightened to a level where the stretch in the bolts/studs is sufficient to keep things so they won't come loose. For those cam cap studs the industry standard for that size fastener is 21Nm but Lotus only specifies a figure of 12Nm (probably to save the threads in the head stripping). At 12Nm the stretch in the studs is insufficient to prevent things coming loose and so locknuts rather than regular nuts are specified in this location
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
On the subject of cam caps, they have been numbered - typical of a machine shop prior to disassembly. I guess Lotus could have done this, but neither of my heads has numbered caps. This would lend more weight to Rohan's observation about the numbered valves - which are possibly in the wrong cylinder.
It is still an interesting find, but it does look like the head is a bitsa.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Andy8421 wrote:On the subject of cam caps, they have been numbered - typical of a machine shop prior to disassembly. I guess Lotus could have done this, but neither of my heads has numbered caps. This would lend more weight to Rohan's observation about the numbered valves - which are possibly in the wrong cylinder.
The cam caps should be numbered 1 to 10 and should match the numbers stamped on the head top surface adjacent to each cap. Some cam cap sets have other identical numbers on them also on early heads which appears to have been to keep the cam caps sets together. I have always presumed this was done during manufacture and not after during servicing due to the quality and consistency of the extra number stamping
