What did you do to your Lotus today...
This topic contains photos of the bush extractor/insertor that I made, many years ago when I had a functioning lathe.
lotus-suspension-f42/suspension-bush-removal-t16368.html#p290008
One pic from the list:
Graeme,
Glad to see you bought one. I posted the other year after helping them get the dims right for our cars.
Quite interesting watching how much camber change there is from bump to droop. I know it makes it harder watching two clocks but once you get set up at ride height with the clock plungers mid postion you get to see everything as you go up and down.
Good luck. Did you see the little clevis i made bolted to a socket for consistent jacking without slipping and damaging wishbone paint. Cheers Mike
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Replaced points, condenser, rotor, distributor cap, coil and shortened the spark plug wires in my S2. Then adjusted the timing. Purrs like a kitten.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
miked wrote:Graeme,
It's a great piece of kit. I'm jacking on a wooden stick to the hub so it pivots with the camber changes.
The hub plate is drilled for 26R hub and the 5 pin hub.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
I watched the you tube video and learned how easy it should be to install the wiper motor. That's my next project on the S2 SE.
Also painted the engine covers base coat for the Elise. Red. Tomorrow will be to do the green, yellow and silver.
Frank
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
