What did you do to your Lotus today...
actually, just reading this, i just got back in from an evening sunset cruise in my Sprint all along Rt 9.....
until i got to a flooded section of the road near a bridge. it was high tide and that happens around here, so a quick U-turn and on we went, wife and i. LOVE driving my Elan on back road cruises....
TED
- tedtaylor
tedtaylor wrote:i assume the tires don't rub as the fenders are flaired/customized a bit? Looks great with the larger wheel/tire combo.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Finally tired of 95 ֯F (35 ֯C) weather & 10% ethanol fuel making the car very difficult to start when hot so installed an electric fuel pump:
Everything fitted nicely in the space between the spare tyre & fuel tank. Electrics are mounted on the sub-box which is also used to mount the hi-fi amp.
Between Amazon for the fuel pump & eBay for the relay & inertia switch it came to about $60 total.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Raydyot style mirrors, standoff brackets, trying to get the center mirror to quit drooping (copper inserts!), the continuing saga of TTR mags rubbing TTR upper control arms, fashioning bits of wood for easy lifting. The project advances more quickly After Corona (AC) than Before Corona (BC). John
- baileyman
Went out to check tires, wheel spinner torque and go fuel up for a planned club drive-upon starting the motor I found rough running as if on less than the number of available cylinders that worsened with a bit of choke. Got out, found a heavy fuel odor and found a steady drip of fuel from the front carb along the back next to the inlet manifold side via an absent throttle housing cover plate! I haven't had the carbs off before so I have no idea how long the cover has been gone.
Pulled off the carbs, inspected the upper chambers thinking the needle valve or float might be off. No sloshing fuel in floats or bubbles with a test in pan of H2O and float measurements of 8.5/15mm were spot on.
Replaced needle valves with new 2.0 units and upper cover gaskets, also replaced carb mount plastic spacers and new o rings with Thackery washers on bottom and rubber mounts on top-was able to maker sure spacer/washer distances are now equal-think they were off a bit before with two different types of plastic mounts previously mounted.
Also put on new cover plate/gasket on the front carb missing these items-seems to have done the trick with the car running well with no leaks and carbs balanced. Would have been nice to have an electric fuel pump or one with a lever given the 15 or so cranks of the starter to fill the fuel chambers but not too worried with new fuel pump and gear reduction starter in place.
Cheers, Mark Whitaker
69 Elan S4 DHC
45/8396
69 Elan S4 DHC
45/8396
- mwhitaker
baileyman wrote:Raydyot style mirrors, standoff brackets, trying to get the center mirror to quit drooping (copper inserts!), the continuing saga of TTR mags rubbing TTR upper control arms, fashioning bits of wood for easy lifting. The project advances more quickly After Corona (AC) than Before Corona (BC). John
The upper wishbones need a heavy hammer! In the end I cut them with an angle grinder, bashed them in and then TIG'd them back together. Remember to do your trial fit with the lower wishbones at least vertical ( or slightly lower ride height)
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Milestone event for me today. The body was separated from the chassis! And during these difficult Covid times, removal for me was a simple one-man job with the 4-post lift and integral overhead crane rail. I fabricated a lifting jig which was fastened to the sill beams using the same bolts inside the body. I was curious about how much the body itself weighs so I bought a digital scale to attach to the hoist. 23.8# for my lifting jig and 262# overall for a net body weight of 238.2#. Obviously lighter for my Plus 2 being a CN Cabriolet version. Anyway, it's nice to be a part of the body removal club now. Someone should make t-shirts for us!!!
Cheers!
Cheers!
'73 Elan +2S 130/5 Cabriolet
Hethel_Haus - First Gear
661 wrote:...
Indeed. Filing, bashing, grinding, bending all seem to be required. But now I think the main culprit is the bolt holes are in the wrong place, need to move up and out. These arms should come without holes and with instructions.
And yesterday, springs on and off three to four times and now ride height is now really close to correct with horizontal arms. (On a different day I will deal with camber.) There is a low priced coiro door mat at home Depot that makes excellent interior mat, however with a reduction in lightness. Pondering how to get the throttle friction out of the TTR race box design. John
- baileyman
Hethel_Haus wrote:Milestone event for me today. The body was separated from the chassis! And during these difficult Covid times, removal for me was a simple one-man job with the 4-post lift and integral overhead crane rail. I fabricated a lifting jig which was fastened to the sill beams using the same bolts inside the body. I was curious about how much the body itself weighs so I bought a digital scale to attach to the hoist. 23.8# for my lifting jig and 262# overall for a net body weight of 238.2#. Obviously lighter for my Plus 2 being a CN Cabriolet version. Anyway, it's nice to be a part of the body removal club now. Someone should make t-shirts for us!!!
Cheers!
Great work!
1967 Lotus Elan Coupe - Super Safety
2019 Tesla Model 3 Performance
1973 Ford F100 4x4
1973 Ford F100 4x4
MrBonus - Second Gear
...[/quote]
Pondering how to get the throttle friction out of the TTR race box design. John[/quote]
That doesn't sound right. The throttle in the pedal box has virtually no friction when it is not attached to the throttle cables. So much so that it you hold the box horizontally in the air and alter the angle slightly the throttle will spin around.
PM me for pictures if in doubt.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
dream cars, you are in the company of greatest my friend.
got my sound reduction started, adding weightness.
elise
elise
Love your Mother
Earth
Love your Mother
Earth
I am doing what must be a least my 6th diff change. (This time from 4.55 back to 3.77)
Following previous grinding off of metal from the front lower part of the casting as previous posters advised, removal was a doddle.
Yet today as darkness fell, I was still struggling to refit the damnable object.
Colonel Croucher seems just to be able to throw it back in, ( 00:42 ) https://www.youtube.com/watch?v=-12F0s58y6k
I am no longer able for the Schwarzeneggar lifts, so tomorrow I will be fitting some scaffolding in the pit.
This time I will record exactly how I was able to achieve this.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
