What did you do to your Lotus today...
Mazzini wrote:Getting ready to put the engine and box in.
Good luck, Rob, I can almost hear it running!
I'm surprised you have a standard manifold (I note the outlet fitting is different to original) rather than a 4-branch, even I gave up on mine a few years ago. I thought the expansion box was unobtainable now; there's not much demand as I only had one replacement.
Meg
Thank you.
If you look closely you'll see that it's a two part cast S/E manifold, they didn't have an expansion chamber, just two pipes that formed a Y piece that then fitted the centre pipe.
I think this manifold was used on S2 S/E's and S3 S/E's. I guess in late '67 Lotus went to tubular systems. My S3 is from April '67.
Mazzini - Coveted Fifth Gear
Mazzini wrote:Thank you.
Apologies Rob, I see it now and I'd forgotten they were one-piece. I didn't know there were any about.
Meg
Mazzini wrote:I think this manifold was used on S2 S/E's and S3 S/E's. I guess in late '67 Lotus went to tubular systems. My S3 is from April '67.
Not entirely. The federal emissions manifold in my '70 Plus 2 (built in late '69) looks like that except for having the two holes on top where the preheater tubes connect.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
JonB wrote:Crowd goes “Oooooooh!”
And that’s a nice looking workspace you have there as well!
The Floor looks toooo clean. Maybe there's no Oil in the Engine
- alan.barker
The problem is when the Bellhousing blocks on the Engine Mount Lugs.
That's why some fit the Gearbox first then fit the Engine.
I did notice you already had the Generator fitted which makes it difficult to get to the Engine Mounting on the Exhaust side.
- alan.barker
The dreaded "bellhousing lock". Why is it some Elan's are easier that others? Production tolerances?
I would have fitted the gearbox first, but it's a close ratio gearbox and a six bolt lip seal engine, which means it has a very thin spigot bearing - thin equates to fragile, so I wanted to make absolutely sure that the spigot bearing was perfectly aligned, hence mating engine to gearbox first.
No issue with the generator side engine engine mount, with a jack and a block of wood under the sump everything lined up nicely.
Good for you Rob getting the engine and gearbox installed. I take it that you did it without anyone helping.
I've got few things to fix or replace after the paint shop finished my car. They retired after that and I didn't notice a few problems that aren't paint related.
Bob
Bob
Bob
1969 S4
1969 S4
- lotocone
Nice one Robin! I’ve been busy building shelves in the garage and making more space. Was sorting out the spares department this afternoon.
Also got the major components of the diff ready to ship to Al (promotor) once everything has calmed down. His work is superb.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
Rob, good that your son could help you out. A friend once helped me with his hoist to get an engine installed, which was a big favor.
I pushed the car out of the garage for a few photos. The paint color is Signal Orange which is a Porsche color from the period. I would have preferred Lotus Colorado Orange, but the painter didn't have a code for it and we were running out of time. He was about to retire with his coworker.
In one picture you can see the L shaped plastic trim by the windshield and around the small vent is broken. Now that the windshield is in the car with new rubber seals, I hope a new piece can be fit without removing the windshield.
Bob
Bob
Bob
1969 S4
1969 S4
- lotocone
Modified a Porsche Jack ($50 of eBay) as recommended by a few here...
Now I need to find a spare wheel but very conflicted as I am not adding lightness to the car!
- mbell
