What did you do to your Lotus today...
Changed a flat tire. On my way to a club event and the sidewall developed a small leak a mile from my house. Limped back home and changed the spare in short order.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
My s2 arrived today. It is a full resto so needed pushing down the driveway. Once we got it down, we set off straight away to get it sorted. In three hours we had managed to remove the engine and ancillaries (not bad for ammeters).
The car is now sitting snuggly next to the s3 and we await until next weekend to carry on or work.
Best regards, P
Best regards, P
Peter James Evans
1965 Elan S2 (Early 26R replica)
2001 Citroen Saxo Hill Climb Car
2004 Mini R52
2004 Mini R52
- Elan Peter
Determined after much head scratching and wooden mockup modeling that neutral bumpsteer for a TTR setup was with the steering rod sloping 11 degrees down. Just under 1/2" of spacers under the rack would give that figure. Not having that, the full half inch gave nearly the same result. Then, thinking what the tire patch is doing in bump is more important than in droop, I moved the neutral point up another 1/8" of spacers, 10 degrees down. On measuring toe through full bump, it seems pretty flat in the range. So this will be my initial setting.
- baileyman
baileyman wrote:Determined after much head scratching and wooden mockup modeling that neutral bumpsteer for a TTR setup was with the steering rod sloping 11 degrees down. Just under 1/2" of spacers under the rack would give that figure. Not having that, the full half inch gave nearly the same result. Then, thinking what the tire patch is doing in bump is more important than in droop, I moved the neutral point up another 1/8" of spacers, 10 degrees down. On measuring toe through full bump, it seems pretty flat in the range. So this will be my initial setting.
sounds quite a bit, I recall for my S4 it was less than 1/4" (possibly even closer to 1/8") but all cars are a bit different on a sensitive issue like that steering rack holder plate I guess... I checked the actual bump steer using a laser pointer attached to the hub which I would take up and down around the operating point by a hydraulic jack, and I recall the sensitivity of shim thickness was quite high (had to make specific thickness shims combination to get to the sweet spot, which was within a few tenth of a mm), but was very pleased with the outcome.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
I finally fixed my leaking twin cam engine cover for good!
Here's the video that shows how to do it. Please feel free to share - I'm sure it will help a lot of twin cam owners!
https://www.youtube.com/watch?v=ngXf0CB ... 0hTp-kYKYF
- originalsprint
originalsprint wrote:I finally fixed my leaking twin cam engine cover for good!
That looks like a nice modern approach. Who did the routing for you?
JonB - Coveted Fifth Gear
JonB wrote:originalsprint wrote:I finally fixed my leaking twin cam engine cover for good!
Colin Denyer - a great chap!
- originalsprint
rcfurse wrote:Can you tell us how to get hold of him?
He's retired now - this was his last job! However, I'll get back in touch with him and see if he wants to do some odd machining jobs here and there. Best.
- originalsprint
No the machining data isn't available as of this post date. If I can get it I'll let you know. However, there are differences in each engine cover especially early to later ones so it almost needs a bespoke service every time. Having said that, if there's a machine shop out there that would like to take on this task as an ongoing project then that would benefit a lot of people...
- originalsprint
Went to a restoration shop open house. Big turn out due to glorious weather in NJ/PA.
Glen
