What did you do to your Lotus today...
The Veg wrote:I still think that they're rare here, but that sometimes things happen close-by like that.
I think your right. Just strange that of the 5 +2 owners I have met in person (including myself) 3 have owned 5 speeds!
- mbell
Starter reinstalled and out for a quick test drive... and decided to take the opportunity to play with recording sound.
https://youtu.be/u2JM0pB6mls
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
MrBonus wrote:Finally replaced my old, somewhat rusty radiator inlet grill.
Hopefully you did you discard the original one, esp. as it does not look too bad when seen from here: I'm sure if you don't need it that would be cherished by someone else, as the original grill pattern is not easy to source...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
nmauduit wrote:MrBonus wrote:Finally replaced my old, somewhat rusty radiator inlet grill.
I don’t throw out anything from the original car. It likely could be easily cleaned up and rattle canned to new.
1967 Lotus Elan Coupe - Super Safety
2019 Tesla Model 3 Performance
1973 Ford F100 4x4
1973 Ford F100 4x4
MrBonus - Second Gear
SENC wrote:Starter reinstalled and out for a quick test drive... and decided to take the opportunity to play with recording sound.
¡W0W! I hope my car sounds even half that good when I get it back on the road!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
Changed the oil in diff and gear box on my +2, fill plug on diff well hidden so decided to us a small pump to refill worked well , used it for the gear box .
I cannot think i am the first to do it just thought it worth passing on, fantastic forum for learning how to look after these cars
Peter
Peter
- hamm61
I started re-assembling the front suspension and doing the brakes. Then I ordered new toyo tires T1R. Hope they will arrive next week.
- rolbydo
Nice one Barney, did similar a couple of weeks back... Great milestone and close to taking a trip out.
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Adjusted cambers. Spec -1% front, -1.5% rear. Measured the actuals on an iphone app with apparent .2 degree accuracy (what did mechanics back in the day require?). Anyway, sine of the delta degrees times the upright length (22.6" rear, 9" front) gave the amount to change the lower link, times 18 threads per inch gave the number of rose join turns.
A test ride to get everything settled, and, it worked! Dang. John
- baileyman
On the iPhone compass app (it’s comes preloaded), there’s an inclinometer on the second page.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
