How D R Y is your TC - this is almost a HATE question!!
PostPost by: el-saturn » Thu Apr 13, 2017 5:21 pm
.........................and i'll start 1st: 2 independant drops coming from the front right oil pan which turn into 6mm dia. once "dry" (12hrs) -------- after a rebuild and advice or assistance from a buddy (alfa mechanic) - i may add another 1/2 kg of torque!? sandy------------------ and as bugs says: aint i a stinker!!
PostPost by: Grizzly » Thu Apr 13, 2017 9:47 pm
Engine is dry on both my cars but the +2 wants a Diff input seal doing and my Sprint keeps leaking from the Speedo drive in the gearbox :(
I know what you mean though, seems to be a constant fix one leak and another starts...... I guess it's the Lotus Anti corrosion system in full effect.
PostPost by: stovekjj » Thu Apr 13, 2017 10:31 pm
My TC is also 'oil' dry, but I have the same seepage on the transmission at the speedo cable. next try for that is a spray bandage !. oh, and I'm replacing a couple of diff seals right now.
stovekjj
First Gear
First Gear
PostPost by: el-saturn » Fri Apr 14, 2017 6:06 am
is it so many leaky engines and a certain portion of shame which we see here or are all the others dry???? sandy
PostPost by: alan.barker » Fri Apr 14, 2017 6:46 am
Grizzly wrote:Engine is dry on both my cars but the +2 wants a Diff input seal doing and my Sprint keeps leaking from the Speedo drive in the gearbox :(
For the leak from speedo drive, is the Breather on the Gearbox blocked :?:
My Elan also had a leak and i discovered it was from the Mechanical Fuel pump. The flange on the Pump was bowed, so i had to file and rub it down flat. Oil had been leaking and running all the way down to the bottom of the Bellhousing. I thought at first it was the Lip Seal on the Crankshaft.
PostPost by: Grizzly » Fri Apr 14, 2017 10:09 am
Thats a good call. I have "Fixed" the drive oil seal three times now and the leak seems to always come back, i thought it was because the drive assembly was so awkward to fit in situ but that would make sense if the breather was blocked. I will have a look Thanks.
PostPost by: ElanDNA » Fri Apr 14, 2017 3:45 pm
[quote="Grizzly"]Engine is dry on both my cars but the +2 wants a Diff input seal doing and my Sprint keeps leaking from the Speedo drive in the gearbox :(
Hi Grizzly
My modification speedo drive with oil seal:
p155.jpg and
Cheers Urs
PostPost by: Grizzly » Fri Apr 14, 2017 6:41 pm
Hi ElanDNA,
Can you please explain what you did?
PostPost by: Certified Lotus » Sat Apr 15, 2017 11:46 am
Since my complete rebuild of the S1 not a drop of oil on the garage floor. Of course, now that I said that something will start leaking......
On the other hand, the 72 Europa I'm restoring leaks engine and trans oil sitting on the dolly. Not for much longer!
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: KevJ+2 » Sat Apr 15, 2017 12:15 pm
ElanDNA wrote:My modification speedo drive with oil seal:
I seem to remember fitting a paper gasket within the angle drive, which I don't see?
Maybe it goes between the drive and the brass fitting?
KevJ+2
PostPost by: ftsoft » Sat Apr 15, 2017 1:02 pm
You mean there are Elans that don't leak!
66 S2 26/5194
LP4711LA-B
ftsoft
PostPost by: el-saturn » Sat Apr 15, 2017 5:53 pm
...........the last comment is more like the responces i was expecting! tbh i was expecting better from my alfa assistant! i mounted the impeller according to the posts i read here: so i maxxed the clearance between the impeller and the aluminum o-ring ring and now my engine would run for a week, idling along at 70 degree C! -- just for you folks who are close to that chore sandy 36 4982
PostPost by: ElanDNA » Sat Apr 15, 2017 5:56 pm
Grizzly wrote:Hi ElanDNA,
Hi Grizzly
I let the picture talk:
p155-1.jpg and
Drill out the alluminium case and make a
centering. Thats all. Urs
PostPost by: KevJ+2 » Sat Apr 15, 2017 7:06 pm
So Sandy, are you talking about a water leak?
I think most of us are comparing oil leaks :lol:
KevJ+2
PostPost by: el-saturn » Sat Apr 15, 2017 9:20 pm
oh yes oil leaks!! to be a bit naturalistic: we dont mind dog pee, we do mind dog manure however - i rebuilt the timing case etc.. incl. all new parts and NO leaks ----- its only my alfa buddy who claimed this and that, pure BS sandy
Next
