1991 Elan - Gear shift cable
Hi there. You are on the wrong forum I'm afraid. This one is exclusively for the original Elan and Plus 2. You need to go http://forum.lotuselancentral.com/search.php?search_id=active_topics&sid=fb0ba5d921b95549dad9ab60e0f5bbf3
Good luck with your quest.
TroonSprint - Fourth Gear
While Mike is correct about this being an early Elan site, I happen to own both versions and have installed a new cable set that absolutely transforms the shift feel and precision from the stock cables. The link is on the Lotus Elan Central site here:http://forum.lotuselancentral.com/viewtopic.php?f=48&t=22769&start=60 Good luck!
- Ross Robbins
Ross Robbins wrote:While Mike is correct about this being an early Elan site, I happen to own both versions and have installed a new cable set that absolutely transforms the shift feel and precision from the stock cables. The link is on the Lotus Elan Central site here:http://forum.lotuselancentral.com/viewtopic.php?f=48&t=22769&start=60 Good luck!
Nicest redirect post I've seen here. Well done Ross!
elanfan1 - Coveted Fifth Gear
