What is this?
I noticed, this morning, a drip from the drain hole under the front of the Elan. It seems to be the colour of caramel only watery but it`s slippery. Not as slippery as oil, more like soapy water, but it`s not that. I haven`t used the car for 4 days, there`s no servo. I`m suspecting brake fluid, especiallly as the master cylinder level is down a bit. There`s no sign of it tracking to where it has pooled in the nose so how could it get there? and where from?
Here`s a blurred pic. but you`ll get the idea.
Jim
Jim
- jimj
P.S. I`ve just been out to check the coolant which IS a similar colour but not as slippery, maybe a bit slippery. Would the antifreeze inhibit evaporation and as the water evaporated, would it feel a bit, just a bit, slippery? I do hope so.
Jim
Jim
- jimj
Yes, antifreeze does feel slippery. Easy way to check if it is brake flu is that brake fluid will remove paint from a surface ( don't try it on your car!) use something else.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
[quote="oldchieft"]Brake fluid tastes bitter, antifreeze tastes sweet./quote]
Do you know this from experience?
Does synthetic oil taste different from dinosaur-based oil?
Herb
26/4618
26/4618
lotusS2guy - Second Gear
Do you have the overflow/ expansion bottle in front of the rad ??
'72 Sprint
'72 Sprint
- richardcox_lotus
If it's wet outside I get some dirty water there. Have no idea what it tastes like.
Fred Talmadge - Fourth Gear
Cat/dog urine?...wouldn't be the first time I've seen a leg cocked up at the front grill.....anyone know what it tastes like??
pharriso wrote:Check your radiator overflow bottle, the bottle may have split or the tube to it may have come out.
Or it may be full and overflowing. Easily done if you take the rad cap off a few times while the engine is hot and you note low level and top it up. It won't suck any back from the bottle if you do that so the bottle will fill up. You won't notice it if you look under the bonnet with the engine cold as it will have sucked back a quantity ( 1/4 , 1/3 ?? ) from the bottle.
Strangely enough, I don`t take the radiator cap off a few times, or at all, when the engine`s hot, nor is our dog sufficiently athletic to pee through the radiator grille, nor likely to. Anyway his pee doesn`t taste like that.
I ran the car up to temperature and can find no leaks, and yesterday I ran the car for, maybe 50 miles or so with no reappearance of the mysterious substance.
How strange?
Jim
How strange?
Jim
- jimj
Cold cup of coffee when standing over the car when the bonnet is open ?
'72 Sprint
'72 Sprint
- richardcox_lotus
Users browsing this forum: DamianB and 22 guests
