S4 Rebuild Apathy !!
• Page 3 of 3 • 1, 2, 3
nobody will read this BUT an elan is like a lovely petite lady: the more you cuddle up with her, the more affection you get back: some call this karma. it?s the same everywhere: lot?s of folks overestimate their prowess; those of us who were fortunate, once worked on racing cars<<<<<<<<<<< elans (most of em nowadays) are racing cars and NOT meant for everybody and they take more much than just simple passion --------------- plus luv ?em or leave ?em -----------it?s real simple ----------- cheers 36/4982 (my new engine i will show very soon; the crank, clutch etc. are now at the balancers shop!!!! yupee!)
- el-saturn
el-saturn wrote:my new engine i will show very soon; the crank, clutch etc. are now at the balancers shop!!!! yupee!)
When I got my crank / flywheel / clutch balanced, it was also balanced with the front pulley which was so far out, I had to buy a new one
Just a thought in case you didn't include the pulley.
Kev.
- KevJ+2
peterexpart wrote:Thank you all for being positive, approached the car with a less negative attitude today, put some fuel in hooked up the Coil and Ign, replaced the Fuel Pump as my new one refused to pull fuel from the Tank !!!, Turned the Key and it fired up straight away, hooked up the Strobe set the Ing for 18 BTDC at 2000rpm and decided that was enough for the day as it was running like a watch.
That is more like it !!
An engine running in situ is certainly a highly pleasurable milstone point to reach.
But you haven't said if you have road wheels an suspension fitted yet.,
billwill wrote:peterexpart wrote:Thank you all for being positive, approached the car with a less negative attitude today, put some fuel in hooked up the Coil and Ign, replaced the Fuel Pump as my new one refused to pull fuel from the Tank !!!, Turned the Key and it fired up straight away, hooked up the Strobe set the Ing for 18 BTDC at 2000rpm and decided that was enough for the day as it was running like a watch.
Bill
The Suspension was the Second thing I rebuilt after the Engine Gearbox Assy, Wheels and New Tyres are on, Brakes on, this morning the Radiator is going on and Electric Fan being fitted, its the only thing to do on Mothers Day !!!!
PeterExpart
New Forest National Park
Hampshire UK
Hampshire UK
- peterexpart
The start of your therapy was by posting on here.
You've had plenty of encouraging words and tales of excitement to come.
If you make it east to Eastbourne you're welcome to come for a spin, so long as no wheels have fallen off my wagon
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
billwill wrote:An engine running in situ is certainly a highly pleasurable milstone point to reach.
Bill, please state whether the missing letter is an 'e' or a 'l'.
Meg
Quart Meg Miles wrote:billwill wrote:An engine running in situ is certainly a highly pleasurable milstone point to reach.
ooops... and I had to google critical path analysis to remember the right word anyway.
