What did you do to your Lotus today...
PostPost by: MrBonus » Sun Feb 02, 2020 12:34 am
Rebuilt the master cylinder that was starting to slowly leak.
1967 Lotus Elan Coupe - Super Safety
2019 Tesla Model 3 Performance
1973 Ford F100 4x4
MrBonus
PostPost by: jk952 » Wed Feb 19, 2020 8:28 pm
Made left and right of these...
B53CFE98-7906-460B-97C2-76F825093EAD.jpeg and
Huh? ...
S3 crash pad on S2 car..so one needs to fill the space.. :)
EE8D5D5A-6101-44FC-8E27-AFD02E7DF481.jpeg and
jk952
PostPost by: David1953 » Thu Feb 20, 2020 6:29 pm
Drove it on the road for the first time since 1983.
Only to end of the lane and back and that was all puddles and mud but, I am not waiting any longer for the rain to stop.
One or two things to fix, like the speedo right angle drive, but nothing fell off and no leaks yet.
elanS3.jpg and
David1953
PostPost by: nmauduit » Fri Feb 21, 2020 1:49 pm
David1953 wrote:Drove it on the road for the first time since 1983.
gorgeous ! beautiful color, too...
If I may, at some point you may consider painting satin black the flat part at the bottom of the sills : it makes for a nicer overall impression at a distance...
S4SE 36/8198
PostPost by: englishmaninwales » Fri Feb 21, 2020 2:09 pm
That’s the colour lurking on my S3 under the gold leaf colours applied (poorly) later in the car’s life.
One day......
1966 Elan S3 Coupe
1994 Caterham 7
PostPost by: David1953 » Fri Feb 21, 2020 9:20 pm
It is black under the sills, only that white mark you can see is wax polish I have not cleared off the very matt finish. It is also now muddy as I did about 60miles today, now got a longer list of things to fix.
David1953
PostPost by: DJW » Sat Feb 29, 2020 5:31 pm
Last time out in car was 4 months ago, so thought I would pop to local garage to top up the fuel.
Funnily enough a 2 mile round trip turned into a 50 mile blat around the Cotswolds, returning with a huge smile ;).
63A95B81-9F3C-4FF5-A5B1-53659C1E2E50.jpeg and
DJW
PostPost by: JonB » Sat Feb 29, 2020 6:31 pm
Lovely.
I washed mine, and swapped out the gear oil (put the Redline back in). Big improvement in change quality.
Also, finished fettling the pods and bonnet. All solid now.
Took it for a quick spin and discovered the fan wiring is still playing up. Bother.
PostPost by: Mazzini » Sat Feb 29, 2020 6:37 pm
Engine and box into the chassis and tomorrow I'll reunite the chassis to the shell
IMG_1409.jpeg and
IMG_1408.jpeg and
PostPost by: The Veg » Sun Mar 01, 2020 12:09 am
Various and sundry small tasks getting ready to put the head back together.
2012 BMW R1200GS
The Veg
PostPost by: baileyman » Sun Mar 01, 2020 12:20 am
Shaped a wooden form to wrap a sheet of aluminum around to serve as a cover for the wheelwell cutout for the clutch master required by the TTR race pedal set LHS. Soon all the master cylinder rods will need to be sized to fit the pedal arm distances.
baileyman
PostPost by: rgh0 » Sun Mar 01, 2020 1:04 am
Finished preparation for racing next weekend at Phillip Island. New Ferodo Dot 5.1 brake fluid, adjusted LH front
wheel bearing as end float had increased a little to much, greased the front trunions. Usual check over of all fluids, brakes, chassis, drive train suspension etc. Found a small crack in chassis where LH roll bar drop link bracket connects , need to put reinforcing patch next time engines out which will be soon, I guess this sort of issue to be expected after 40 years of racing with a big roll bar. Also found one CV adaptor bolt slightly loose so re-torqued that, all the others were OK.
I have got some adjustable front top links to fit and just got an electronic camber and caster gauge for setting it up but ran out of time to get it fitted. Planning on using some A050R Yokos with the soft compound versus the medium compound I have been using and will need a bit more front negative camber to make them work properly and not chop out the outer edge to much
PostPost by: davie489 » Sun Mar 01, 2020 1:30 pm
Hello all
Just done the mx5 fuel non return mod!
Absolutely brilliant , just booted the car out on first day of spring with not a drop of fuel over the rear wing ! Here’s to a good spring summer in the plus 2!!
davie489
First Gear
First Gear
PostPost by: alanr » Sun Mar 01, 2020 5:14 pm
Still not got my ordered since last September MX5 non return valve! However I have finished off today the main fuel tank breather and filler pipe Mod.
2 Filler Pipe Mod.jpg and
3 Filler Breather Mod.jpg and
Breather Pipe Mod.jpg and
Alan.
'71 +2 S130/ 5speed Type9.
PostPost by: Mazzini » Sun Mar 01, 2020 6:30 pm
Reunited - chassis and body shell!
45146366-E10B-46C9-B673-18F5FF691998.jpeg and
PreviousNext
Users browsing this forum: No registered users and 41 guests
