Inverting mold material
I am swapping a +2 Élan Twin Cam, for a Duratec. The problem is, intake manifolds are not available. Sure I will need to make my own, but… Cosworth has done the research already, so I dont need to reinvent the wheel, but… intake is facing the wrong way, and will need to pass through the firewall.
My simple solution would be to buy a Cossie knock off, take a mold, then figure out how to invert it.
There are no 3D scanners close to here that I can find. Or this would be a simple solution.
What I suspect, is someone here knows of a nylon or plastic which once set, can be turned inside out. So a 2 piece mold. Maybe something like a kid “crazy carpet” for tobogganing. Because it is flexible, and rigid. But of course I dont know the exact polymer chain, so this will be difficult If not impossible.
Love your Mother
Earth
Love your Mother
Earth
- Location: RACECAR spelled backward, is——RACECAR! The Faster You Drive...The Slower You Age
I've seen header prototyping kits that seemed quite tempting to play with (a bit like lego), if only for the price...
https://www.trick-tools.com/Icengineworks-Exhaust-Header-Modeling-Systems-864?view_all (no affiliation)
for a one off and not needing to be formula one accurate, even if you want to make a fancy titanium one someone, you could always prototype with mild steel for cheaper I suppose...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
h20hamelan wrote:I am swapping a +2 Élan Twin Cam, for a Duratec. The problem is, intake manifolds are not available..
Have you considered Jenvey throttle bodies? They have direct to head units for the Duratec that include the intake runners and provide more options on air feed. I've run these on my Westfield for years and am using their 2.5L versions for my new project. They have the added benefit of sounding like Webers
-John
JohnCh - Second Gear
Hi, thanks!
Yes, considered both. Wanting to use single throttle body, car is not for me or I would have gone Jenvey. Car is for my brother and I need to keep it simple for him. Not that there should be more issues with Jenvey, I figure Cosworth has it dialed.
Love your Mother
Earth
Love your Mother
Earth
I see there are apps for 3D scanning
Maybe problem solved
https://www.google.ca/search?q=ipad+3d+ ... ent=safari
Love your Mother
Earth
Love your Mother
Earth
Found a local (100 miles away), with a large 3D printer.
So off to the races I am!
Love your Mother
Earth
Love your Mother
Earth
Love your Mother
Earth
Love your Mother
Earth
