Garage floor covering
Hello and a Happy New year to everyone
I am thinking of covering over my garage floor and am looking for advice & thoughts from anyone who has had recent experience doing this.
I am looking for something that will achieve a sound durable surface that's easy to keep clean and hard wearing, also easy to lay, low maintenance and doesn't cost the earth.
So tiles ceramic/porcelain or plastic/composite, paint anything anything else ???
Paul
- Paul Chapman
I used a 2 pack gloss grey after acid etching the floated concrete floor.
If your floor is smooth then paint is excellent.
I've had no issues with peeling paint off even after hot Avon ZZRs have rolled across it.
https://www.watco.co.uk/paints-sealers/ ... -paint?p=0
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
661 wrote:I used a 2 pack gloss grey after acid etching the floated concrete floor.
That's what I have done also. Its hard wearing and makes cleanup of spills easy and also finding of dropped nuts and washers easy
I added a Polymer grip aide to mine. So oil, water etc, its not slippery. Not as easy to squeegee, and sweep, but…i hate slipping.
Really, the sweeping is not so bad.
Love your Mother
Earth
Love your Mother
Earth
- Location: RACECAR spelled backward, is——RACECAR! The Faster You Drive...The Slower You Age
h20hamelan wrote:I added a Polymer grip aide to mine. So oil, water etc, its not slippery. Not as easy to squeegee, and sweep, but…i hate slipping.
This is one of the concerns I had about water or oil on the floor causing a fall. Is the polymer grip aid an additive or another layer of coating? Would like to learn more.
Dan
I have recently painted a new concrete garage floor. The floor texture wasn't that smooth, so no grip enhancer was necessary. I used:
https://www.screwfix.com/p/leyland-trad ... 5ltr/49596
Not as fancy as a 2 pack product, but indications so far are that is is durable. I gave the floor 2 coats with a roller, the first thinned (as per the manufacturers recommendations), the second coat un-thinned. I used approx 12 litres in total for a 5.5m square garage.
it is much cheaper than a 2 pack product, but does need a 7 day cure period.
71 Elan Sprint (to be restored)
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
- JimE
Using porcelain tiles is great for a smart garage to keep the car, however if you work on the car, they are very cold in winter and they may crack if you drop tools on them
- mikealdren
Shark Grip is what I use, did my laundry room too.
Make sure your floor is extremely clean!
Love your Mother
Earth
Love your Mother
Earth
@h20hamelan Thanks!
My garage floor is not all that smooth and was in a terrible state with oild etc in lots of places. I spend about 10 hours degreasing the floor with standard oil degreaser products and then grinded off splats of old paints with a stone cutting disk on my angle grinder. I made sure the floor was clean and dry then painted it.
Very happy with the final result; sorry the picture is the wrong war around (I can't see how to remedy this on the page)
Tony
Elan S3 S/E DHC
Elan S4 S/E FHC
Audi A1
Elan S4 S/E FHC
Audi A1
- TonyWalker
TonyWalker wrote:I used Rustoleum Epoxyshield Garage Floor Paint.
Tony
Nice job of the wall, Tony
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Hello again
A big thanks for all your replies, it seems as though an epoxy paint finish is the way to go. My garage floor area is approx. 5mts x 6mts, sound with some wear and with a slight slope from back to front, so not sure about a self levelling medium. It seems to have been sealed with something in the past so hopefully it will degrease/clean up okay. I just want to avoid anything that will lift away when a vehicle is driven out or blisters when wet for a period of time.
Best regards
Paul Chapman
Best regards
Paul Chapman
- Paul Chapman
Personally I have yet to find any make of epoxy floor paint or otherwise no matter how carefully the surface is pre-cleaned or applied that doesn't lift or blister over time from either warm or wet tyres.
Alan.
Alan.
'71 +2 S130/4
'71 +2 S130/4
- alanr
alanr wrote:Personally I have yet to find any make of epoxy floor paint or otherwise no matter how carefully the surface is pre-cleaned or applied that doesn't lift or blister over time from either warm or wet tyres.![]()
Alan.
The Watco one I have has not lifted in 9 years. As said, that's with hot Avons running over it that were on the Exige.
When I suggested the floor should be 'smooth', it doesn't need to be mirror finished.
Small indents will fill.
If you are considering Watco, I'd phone them and ask what they recommend for preparation. I found them very helpful. It's not cheap, If I recall I needed 2 tins of about £120 each and a small amount for the acid etch.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
