fastener with a 90 degree loop?
PostPost by: ted » Tue Dec 14, 2021 5:01 am
rsz_img_1127.jpg and
Does anyone know the name of the item pictured? It's has a tab on one end and a loop 90 degrees from the hole in the tab. I'm looking for a source, but don't know what to ask for.
Thanks for any insight.
Ted
ted
New-tral
PostPost by: john.p.clegg » Tue Dec 14, 2021 7:50 am
The nearest I can find is this...
https://www.autokrafters.com/Ford-Musta ... bc-10.aspx
Grommet and bracket
John ;-)
PostPost by: oldelanman » Tue Dec 14, 2021 7:56 am
If you can't locate that particular item maybe a rubber lined P clip would do the job?
apijr7jfr__89937.1609921754.jpg and
S4 DHC
PostPost by: Lotusian » Tue Dec 14, 2021 12:26 pm
I’ve seen this sort of thing described as a stand-off
Lotusian
PostPost by: elans3 » Tue Dec 14, 2021 4:09 pm
As the one in the photo is on a Porsche 911 engine fan housing, might be a good idea to have a look at Porsche air-cooled specialist websites....
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
PostPost by: ted » Wed Dec 15, 2021 5:49 pm
Thanks, guys for your insight and suggestions. It appears the correct name might be a standoff, but there seem to be hundreds of variations. Gives me a good start for further investigation.
Ted
ted
New-tral
PostPost by: Frogelan » Thu Dec 16, 2021 7:54 am
Ted
I had a rummage to see what I could find. This "Zündkabel halter" part is not a million miles off:
https://partworks.de/partworks-de-Porsc ... DREHT.html
I'll have a further look at the weekend.
Andrew
Frogelan
PostPost by: 2cams70 » Thu Dec 16, 2021 11:16 am
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: ted » Sat Dec 18, 2021 7:25 pm
Exactly what I'm looking for. I just assumed it was a more general purpose item, not what appears to be a proprietary piece, but it appears to be a quality part. Thanks for finding it. Ted
ted
New-tral
PostPost by: vstibbard » Wed Jan 12, 2022 10:37 am
Check out race service 4 u they make the ignition wire loops that are used on 12 plug Porsche engines. I recently purchased some and I’m about to get the pleasure of seeing and enjoying my 2.8RSR spec engine after a long and frustrating rebuild.
The engine rebuild costs alone would fund a first class Elan restoration!
