Oil stain removal
Hi there, Can anybody recommend a product to remove an oil stain on a concrete hard standing? Concrete been down about 18 months and I did mop up most of the oil following the spill last weekend but it has soaked into the concrete.
Plenty of products available but wonder whether anybody has first hand experience with any of them
Martin B
Martin B
- martinbrowning
Try and lift as much out as possible using absorbent agents, sawdust is good, cement even better (they use it on race tracks) biological washing powder is quite good and helps with stage 2
Stage 2 scrub well with detergent and boiling water and then pressure wash until you can no longer see any rainbow colours of the o?l being swept away with the water.
the stain will still be visible but usually becomes less visible as time goes on.
A Customer dumped a lot of really dirty diesel sump o?l on my lovely block paved car park (laid by my own hands) I didnt see it in time and have done stage 1 and 2 but not yet pressure washed it, the stain still looks very black
- Chancer
I use cat litter over night. Then sweep up and pour another mound of it and let sit overnight again. Pulls most of the oil out of concrete.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
B&Q Concrete cleaner and then power washer the trick is not to let the oil dry in, so pour kitty litter / Absorbent Granules over the oil making sure you don't spread it further and rush over to B&Q from past experience the longer you leave it the harder it is to shift. Always worth having a bag of Oil Absorbent Granules about for such occasions.
Concrete does clean up quite well (might take a couple of attempts though) but don't try this on Asphalt drives etc (it will start to soften the drive)
Grizzly - Coveted Fifth Gear
It might sound silly but as a last resort I was able to use sandpaper to sand out a thin layer of dark oil stain from my garage floor before my wife could complain about it. Whew
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
I've used a couple of different products specifically made for removing oil from concrete. Both were available from the local hardware store (USA) and did a very good job for both new and old oil stains. Removal of the 50+ year old stains required grinding the floor. This was done prior to painting the floor of the garage. Good luck.
- DeanG
I recently epoxy painted a 75+ yr old concrete floor. I just used the two stage system from the local DIY store. There were lots of oil stains, as you can imagine. The first stage is a chemical clean which bubbles out old oil, then next stage is paint mixed with epoxy. Try to find the first stage. I think it is sold separately as well as in the kit. If you have the time, it takes a two day process to do the full monty, but I highly recommend it. A paper towel cleans up oil now. Good luck. Dan
Get a blow torch and burn it off, for small drips.. Works EVERYTIME
